This year I took down my old layout because I had some work to do in the basement. It was a good excuse to redesign the whole layout. I am using the same postwar ZW for track power but added a CW80 I got in a set at Christmas to the 1033/1034’s I was using for accessories. All the commons are connected. Initially, I set the CW80’s accessory voltage to 14 using a cheap Radio Shack multimeter so it would match the 1033’s. Everything was working fine, and actually still does. However, the CW80’s green light has started to blink when powered up. The only things on the accessory circuit right now are Super O 112 switches and some Super O uncoupler tracks. I noticed when the uncouplers were wired up that the CW80 blinked when I activated the uncoupler control. Now, after hooking up about 15 of the 112 switch to controls, and the accessory voltage instead of track voltage, that the CW80 blinks all the time. Other than the possibility of a short somewhere, (I don’t discount it, but everything does work right now) is this normal for a CW80 to do this? Is it compatible with the postwar 1033’s, or should I just leave it out of that group? Is setting the voltage on the CW80 to match the 1033’s with a cheap voltmeter adequate or do I need to use something else to do the job?
First of all, what is the Made in China date-code on the bottom panel of your particular CW-80?
The “common” posts for a ZW are U; for a 1033 they are A or B; and for a CW-80 they are either A and B, or U under A and U under B, depending on the Made in China date. This could well be the key to it.
To measure the output voltage of any version of the CW-80* you need to have a load (at least a single lamp) on the CW, either the throttle or the accessory side, whichever you are measuring. Then, to sharpen up the accuracy a bit, you need to refer to a voltage conversion chart by "lionelsoni " which can be found in the archives of this forum. See “Search Community, Advanced Search.” The postwar ZW and 1033 should read accurately enough straight off the meter.
When we get the “commons” sorted out satisfactorily (the "uncoupler control hook-up is suspect) we can take a look at the load. Unless they are LED’s, the amps drawn by multiple lamp bulbs build up amazingly rapidly.
The usual way of measuring AC voltages is the root-mean-square (RMS, the square-root of the average of the square) voltage. Any AC voltmeter you are likely to have will measure the correct RMS voltage only if the waveform is sinusoidal. Unfortunately, the CW80’s waveform is not sinusoidal. So its voltage can be measured accurately only with a rather special voltmeter.
Here is a chart for converting your voltmeter’s reading to RMS:
Wouldn’t it be more consistent to show the typical amperage of each bulb so that the cumulative draw could be added up and compared to the transformer’s rated output of 5 amps in the case of CW-80’s?*
For example, if the average draw of a single lamp was 0.15 amps (not necessarily a real value) then the CW-80 at 5 amps could power about 33 lamps, assuming that nothing else was drawing on any of the transformer’s outputs, and assuming that my calculation is good enough for government work. (5 amps per transformer divided by 0.15 amps per bulb equals approximately 33 bulbs per transformer.)
The question of which version of the CW-80 is involved here still has not been answered by the original poster. If the problem is a simple overload, it doesn’t matter, but there could be more to it than is immediately apparent. Also, other members might be interested in some of the more tricky “polarity issues” posed by the CW-80 family, and how they affect wiring schemes. Of course, they may not, but it’s an inefficient learning process if the forum provides answers that are useful to only one member at a time. (Nice small classes, though.)
I suppose you’d have to specify the current draw at a specified voltage, or a series of voltages? Rob or Bob?
Maybe, depending on which bulbs are in the switches. But then you don’t have enough overhead to run the switch machines too - you will get the blinking green overload indicator every time even when just one switch point throws(figure ~ 5-7 ohms for the switch coils).
Incandescent lamps are rated both for voltage and for the current that they can be expected to draw at the rated voltage. There is a pretty good rule that lamp current varies as the .55 power of voltage, which allows you to calculate the current at the actual voltage used. For example, the very common number 53 lamp is rated at 120 milliamperes at 14.4 volts. So it can be expected to draw 118 milliamperes at 14 volts, and 133 milliamperes at 17.3 volts, or, in terms of power, 1654 milliwatts at 14 volts, 1728 milliwatts at 14.4 volts, and 2296 milliwatts at 17.3 volts.
Whether there is enough transformer capability left to throw the turnouts may depend on how the CW80’s overload protection is designed. A true transformer (like the 1033) would have no problem even if it were fully loaded by the lamps, since the turnout would have thrown long before the thermal circuit breaker could respond to the overcurrent. This is a good thing and does not endanger the transformer nor the wiring, since they both respond to the heating effects of the overcurrent in the same sort of way as the circuit breaker does. If the CW80 is designed to delay shutting off for, say, 1 second after sensing overcurrent, that would be ample time for a turnout to throw. The light may blink, but there is no harm in that.
Apparently I haven’t been able to “sell” my plea for consistency in units (units of measurement.) The lamp (bulb) specifications that are readily available to toy train operators use amps and decimal fractions thereof. Thus my make-believe lamp, mentioned above, rated at .150 amps (150 milliamps) was certainly in the ballpark, with many Lionel lamps being rated between 100 and 250 milliamps, or, as I prefer, 0.1 and 0.25 amps at their
I am at work right now and will have to check the date code later tonight on the CW80. Everyone else is gone from the house today so I can’t even call and get them to look it up for me. This was a replacement that I got from Lionel (through a local repair shop) a few months ago. The original from the set I got at Christmas had issues that I needed fixed.
On the load, wouldn’t having the 1033’s in the circuit spread the load among all the transformers? The size of the load was the reason I had this number of transformers in a parallel group in the first place.
Thanks Bob for the conversion table, I will have to reset the CW80 and see if that changes anything.
I tried to add this to my original reply, but I think I messed it up somehow.
Anyway, Just a note:
The bulbs are #19’s that go in the 112 switches. The control is a submini momentary toggle with an added LED indicator, so both a bulb and an LED are lit for each switch.
The uncoupler is connected by a single wire from the 14 volt accessory circuit with the common going back through the track. The control is a submini momentary toggle with an LED in parallel. I have several of these and all get the same reaction from the CW80 whether through the control or directly jumping it. From the comments I suppose the momentary blinking is not a problem, though why this load would be causing the CW80 to overload is interesting.
I can’t give this much more time. What I would do, is to run both a “hot” and “common” wire to a bank of lamps that are totally separate from the track and everything else. I would do this for the CW-80, and again for the 1033, completely separate from any track or other accessory connections. Hang a bunch of your lamps on the CW, or the 1033, or split the load between them, but don’t connect both power sources to the same load, and don’t overload either power source. Use the guidance above about loads. Be conservative.
If one assumes that the basic wiring scheme for the postwar ZW is the “true standard” (the U posts are common), then both the early version CW-80’s AND the 1033’s are non-standard (they are quirky) and great care must be taken not to cross-wire either of them in all but the most basic layout.
Feeding the same load with two or more transformers, that is “sharing” the same load, is inherently problematic, in my opinion; and I would only do it if there were no other way to go. Sharing commons, however, (the very essence of the highly- regarded “common ground” scheme) is OK as long as you keep rigorous track of what is common and what is not. The early CW’s and the 1033 family of transformers make it absurdly easy to screw this up.
Try it the straight-forward way. Wire is relatively inexpensive, and well worth the cost to get answer. Leave the uncoupler track out of the circuits until everything else works. If you get it to work in its simplest form, you can always get fancy later.
Do I personally use common-ground systems? All the time. Have I ever screwed one up? Of course.
If it’s too difficult to raise the bridge, lower the river.
Thanks bf I appreciate your help. I don’t post much on these forums because most of my questions are answered by you guys before I can ask the question and my answers are usually the same as what you guys have already said. Great resource.
After I reset the CW80 and check the code and the proper connections to common, if I still see the blinking I will probably try what you have suggested in distributing the load separately. The motor and bulbs in the switches all go to common internally through the track so I will only be able to feed the power through separate wiring from the different source transformers, but that is doable.
I would like to hear your thoughts on why the “sharing the load” is problematic. I see this all the time in parallel batteries, the power grid is sourced from multiple generators, etc. Is your concern back to my original question concerning compatibility between new and old toy train transformers, or the quirky way they are designed? If I stick to just 1033’s in the load sharing is that safer (relatively). Do you find that most people use separate transformers for isolated districts for accessories (except common), with maybe a single transformer powering a high draw accessory?
I am all conventional so I have divided the track into blocks, some of which are fed from different handles on the ZW, partly to run multiple trains separately, but also to isolate a siding or a section of track. I guess on the accessory side it shouldn’t be much different, except I would use different separate transformers instead of handles.
Scott, I’m not trying to blow you off, but I have a personal situation involving minor* surgery coming up very soon and I have a lot to do to prepare.
I have been studying the various versions of the CW-80 since at least 2004. I am by no means an expert on the “innards” but I do know a little about it’s behavior. So let me tackle one of your questions via an analogy. I think that trying to couple two transformers to the same load is inherently problematic in the same sense that “It’s not that one commander is better than another; it’s that one commander is better than two.”
I’m well aware that it’s done, but I suspect it’s more successful when the two transformers are as alike as possible. When Lionel introduced the CW-80, they said it was “unlike any transformer Lionel has ever offered previously.” Evidently I was the only person who read it. After seeing what was going wrong, I posted repeatedly that the more you knew about postwar transformers the less you knew about the CW-80. Everyone laughed, but I was right. To make matters much, much worse, the Lionel factory in China managed to botch the internal wiring in the pre-revision models. This was not a minor error. They miswired the common posts. Their Owners Manuals they were as messed up and confusing as the devices themselves. This went on and on for over threefull years – every single CW-80 sold – until they finally corrected it with the “major revision” in mid 2006. But I have lost count of the posts that have been fired at me by folks who obviously don’t understand or won’t believe it. The factory-miswiring does not always present an operational problem, especially in simple layouts, but it’s always there, lurking. That is why I insist on knowing what version we are talking about.
Now, back to your question about using multiple power supplies on a single load. I know
Here’s why you shouldn’t connect your CW80 and 1033 in parallel:
The 1033 puts out a sinusoidal waveform, which wiggles back and forth 60 times a second. When you set it to 14 volts, for example, the sine wave alternates smoothly between -20 and +20 volts. If you move the control lever, the entire waveform gets larger or smaller, but keeps the same undulating shape.
The CW80 has a 20 volt transformer inside it, which puts out the same sinusoidal waveform, except that it alternates between -28 and +28 volts. It does not change when you move the control lever. This internal transformer is not connected directly to the terminals. Instead, it is connected indirectly through thyristors, or electronic switches. Each half-cycle of the transformer voltage begins with the switch open. Part-way through the half-cycle, the switch closes and connects the transformer to the terminals. At the end of the half-cycle the switch opens again; and the same thing repeats for the next half-cycle. The control lever determines when in each half-cycle the switch will close. This varies the voltage that gets out of the CW80, but not at all in the same way as the 1033.
When you connect the two of them together, the 1033 drives all the load for the first part of the half-cycle, when the CW80’s switch is open. Then, when the switch closes, the CW80 tries to drive both the load and the 1033–backwards. That is, the CW80 takes energy from the power line and pumps it into the 1033. This involves a lot of extra current flow and may have something to do with your difficulties.
Something similar happens when you connect two simple transformers, like two 1033s, together. However, whichever one is set higher just continuously pumps energy into the other one, on every part of every half-cycle, unless you have set both transformers to precisely t
Great explanation, I will certainly take it in to account as I finish wiring up my layout.
I did some checking tonight and I have a CW80 with the code of G0908. The black terminals labeled U seem to be internally connected as common. The red terminals are labeled A/track and B/accessories. I had my common connected to the B terminal, so I switched them and most of the blinking light condition went away. I also reset the voltage using the RMS chart and the only blinking left, including the uncouplers, was momentarily when I hit the control for the 112 switches.
I am using the fixed voltage 14v terminals on the1033/1034’s, which is B (common) and C (power), and my ZW250 has the upper terminals labeled common.
So, now after getting the commons straightened out I will break up the accessories circuit so that I am using separate transformers for separate load districts, hopefully sizing them correctly for the capability of the transformer.
BTW, I am using the technique you mention about the opposite phasing of the track and accessories transformers, which I learned from you a while ago.
Thanks all for your inputs, this was great and helped me immensely.
Sounds like you are good to go. Lionelsoni’s last post was a technical tour-de-force, was it not? You definitely have a Revised CW-80, with the “G” prefix, which stands for" good". The best test, as you have discovered, is to place an ohmmeter across the outputs. The common posts will read zero ohms, the non-commons will read several ohms.
In one sense, your 1033 is the odd man out as far as the “common” is concerned. I’m sure you’ve noticed that the plug on the CW is polarized whereas the others are not. Whatever hook-up scheme you decide on, it might be a good idea to put a drop of paint on the top of the unpolarized plugs so that you always insert them into the socket the same way.
The power* of the 1033 is about the same as that of the CW-80, although the 1033 can be overdriven continuously (especially if the circuit-breaker is frozen shut, as many are) and will quickly heat up, whereas in normal operation the CW-80 cannot, due to the active fold-back circuitry. (Always listen closely to ensure that the fan inside the CW has come up to speed.) The factory specs of the two devices were the same in terms of output amps.
I always fuse my postwar transformers at their rated output or perhaps an amp above it if the original factory-built circuit-breaker is suspect, as they all are. I also test mine regularly, although this is not a task devoid of some trepidation, Testing a the internal circuit-breaker on a ZW borders on the wild, especially the first time you try it.
I hope it doesn’t appear that I was knocking “Common Ground” wiring schemes. I use one all the time. It’s just that I sometimes go back to basic point-to-point wiring temporarily when I am troubleshooting. You can learn a lot from Lionelsoni’s several posts on this subject which are in the forum archives. If I understand him correctly, it is ne
Thanks for your kind review of my post, bf. I hope you won’t mind a few additional comments about the subjects you raised.
The 1033 is not the eccentric that its terminal labeling makes it appear. Actually, Lionel was pretty consistent in connecting the U terminal to the wiper on all their postwar transformers with a single voltage control, like the 1033. Their inexplicable inconsistency was in using the completely different convention of U as common in all the other, multiple control, transformers, like the Z and ZW.
I agree that marking plugs is a good idea. My preference is to mark the side of the plug that goes to the grounded conductor. This is consistent with the NEC philosophy of always “identifying” the grounded conductor, whether by white color, ridge on the zip cord, or whatever. The grounded conductor is the fatter blade on modern American plugs.
As you say, the common conductor can get very large. This is a consequence of the fact that the ampacity of a wire increases only as the 3/4 power of its size. One way to mitigate this is to wire transformers so that their commons stay separate for much or all of the distance between them and the track. For example, I use two (15-ampere) type-Z transformers on a roll-around cart, but with separate 14-AWG common wires in the tether. If I had combined them at the cart, I would need a 10-AWG wire, which has about 2 1/2 times as much copper in it as a 14 AWG.
I tend to prefer using metric prefixes to avoid decimal points, for two reasons: They are easily lost when printed or hard to see in many computer fonts, like this one And the United States is almost alone in using the period or dot as the decimal point. The comma is much more popular in the rest of the world, with the period used where we would use the comma. So I avoid commas entirely; and I write quantitie
