I hope this came out,it’s my first post, it’s my mock layout 17ft x19ft Nscale, let me know if this worked.
Not unless you were trying to show us how NOT to post a photo. [swg]
And [#welcome] to the forums, BTW!
If the track plan consists of two point-to-point lines that cross each other, then it came out ok.
When constructing your posts, notice that on the box you are typing in (or posting pics on), there is a tab that says “preview”. When you click on that, it will show you your post before actually posting for real. Gives you a chance to see exactly how your post will look like before anyone else does. Then you can fix anything that didn’t come out the way you wanted it beforehand. If you’re having trouble uploading pics, search this forum. There is about a hundred thousand threads on the subject. Good Luck!
Matt
Your photo must first be downloaded onto a Host ,eg Photobucket.com You choose the Album into which you place the photo and below the photo will appear four tags. Click on the bottom IMG one, and momentarily it will say “Copied”. Or if the photos are thumbnails, there will be a small square below (on the left end), and a rectangle below that. When you click on both of these and then click on the upper Tool Bar “EDIT” and then scroll down to click on “COPY” . Now go to the Thread that you wish to Post on Trains.com/Forums (or as a Reply), and complete your Text message. If you then click on the ctrl and V keys the lengthy photo code will appear. Then, when you click on POST , your Thread (with Text and reduced photo) will then appear at the end of the Forum . You can always Edit or Delete your Posted Thread (or Reply). Good Luck Bob Hahn
