Purchased 4 of these turnouts but canonly get it to throw oneway only, I have tried everything I could with the wiring but nothing works even when back to old atlas swith control and nothing need help badly
Mike
Mike
[#welcome] to the forum and Merry Christmas. Your posts will be delayed in moderation and we may not see you reply until next week.
I found these wiring directions on HO Seeker.
https://www.hoseeker.com/modelpower/modelpowercatalog198%20pg08.jpg
Hopefully someone will have a wiring explanation of why you only have one way operation. I have never used Model Power turnouts, but they look like atlas clones.
You can’t put the ampersand or quote or inch marks in the title of a thread without it looking weird.
You do have it hooked to AC right?
I like those controler levers.
Mike.
I hope so all other 12 atlas snap switches work
found the wiring for model power turnouts and now they work. Black wire is the common wire, green is closed, red is open hope this helps all that have turnout that are not working.
Mike:
[#welcome] to the Model Railroader forums. I hope you stick around.
I wish I would have seen your questions earlier, I knew the answer.
Oh well, maybe next time.
-Kevin
