Model Power HO scale Dockside Switcher
I think that I should by one because my train layout is on the smaller side.
I have a similar model be Model Power, the Plymouth one, and I found that most of the weight was right in the middle, and had little weight on it’s only driving wheels, which are on the rear axle. I removed the weight, put it behind the motor in the cab, and put some other weights in the front. After this it had gained a pound or two of weight, and can now pull 7 or 8 cars, not 3 or 4. if I had even better weights, I would be able to make It weight even more.
