Ok I am tasked with dealing with the club’s laptop. We already had the earlier DVD set and did it as a hard install (no disc drive in the computer and had used my external hard drive to install.) We just got the 10 Year archive and I am having some issues. First of all I did figure a way to move the files into a folder on the hard drive. Regardless if I am using a disc or the folders however I am getting a pop up box in Adobe “This document is trying to access… If you trust this document choose allow. If you do not trust this document choose block” when I click the menu to go to the year and then again to go to the individual issue. I did do the “uncheck open cross document links in same window.” I did try using a couple of other PDF readers and Edge, Chrome, and Firefox as well to see if they did better in opening it and they were not functional with the PDF links at all. So is there a solution to the trust window issue with documents where that pop up does not come up?
