What were/are metal trains made from? I keep being told brass but it doesn’t look like brass. HO scale are the ones I have. Thanks.
In the past there were two types of minature trains sold. The least expensive ones were referred to as “tin-Plate”. The better ones were made of Brass. Some brass ones are still made, but are quite pricey.
If you take the shell off, brass ones will look like brass.
I thought they were made out of money.
[#welcome]to the Forum. Your posts will be delayed in moderation for a while.
We can’t see your trains.
Some were made out of brass and if painted, that may not be obvious, some metal high in zinc (and they suffer from zinc rot) and some mysteriously referred to a diecast, which is non iron/steel mix.
If they are not brass models then they are a probably a pewter-like cast metal that goes by many names and formulas.
-Kevin
Bones) Model trains have been made from many metals over the last 100 years. And not in just in HO scale. Scale in this case is irrelevant.
Best way to tell what a model is made of is visual inspection.
You will actually have to look at a part of the model where you can see the ‘bare metal’. Then you can determine ‘what metal’ it is made of.
If the model has been painted, and alot of brass models are painted now-a-days, you may have to get into the nooks and crannies to see bare metal (upside down or inside model maybe).
Alternate ways:
Get the manufacturer name. Brass models are easily determined that way. As is any other type of model.
If unpainted, its obvious what metal it is, but if painted… get the type, roadname, roadnumber, and class of model if possible. This can also be used to trace a model.
Buy it NIB where youll know its brass, OR, from one of the hobbys many reputable brass dealers.
Clear Ahead!
PMR
Best answer so far! [(-D] [(-D]
PMR
For something that heavy. My pocket sure gets lighter
Many trains were made from ZAMAC. An alloy of zink, aluminum, magnesium and copper. Some like early Bowser were lead. Then you have tin plate which is a stamped sheet metal.
Pete.
What trains do you have? A lot of different metals have been used, but brass and zinc diecast are the most common.
