This discussion is starting up, off-topic, in the detailed-RTR-operating-model thread. It deserves its own named thread for discussion.
Some of the discussion thus far is as follows:
[quote user=“ATLANTIC CENTRAL”]
Lastspikemike
Yes, thanks, I’ve actually previously book marked that extensively detailed description. [This is the link to big blue trains.com on improving adhesion for light models.] Thanks.
The disparity in pulling power for these steam locomotives has me pondering coefficients of friction on nickel silver…
However, I noted an extensive thread on locomotive drawbar force as it may relate to the coefficient of friction of steel on steel as well as steel on sanded steel comparing prototype to HO.
In light of the significant disagreements evident there I decided not to make my own contribution. The topic seems surprisingly controversial, given that the physics have been well understood for over 100 years.
Interestingly, diesel models seem quite predictably uniform in their pulling power and roughly correspond to prototype patterns: bigger and heavier pull proportionately better. This is not the case for steam locomotive models which is frankly a bit weird.
It is not weird at all. Model steam locos, even with spring drivers suffer from a lack of even weight distribution on the drivers, as well as other traction losses on our sharp curves, etc. This problem increases with the number of d
