Just looked at the first page of General Discussions and Layout Building and saw generally 0-20 replies on many topics I might actually employ on my layout. On the much replied to "How to Series. . . there are over 100 replies to the first, 50 to the second and a just now third segment recently posted. I would expect that maybe a precious few viewers would ever employ such a method yet hundreds might use other modeling methods discussed in far less replied to posts.
I am not griping on complaining. I’m just saying it is amazing the time we will spend replying to something we will never utilize but another poster wants some legitimate feedback on an aspect of the hobby many might use and there are only a half dozen replies. Maybe it is similar to why folks rubber neck at accident scenes and the news is full of mostly bad news. Our base instinct is towards the bad and negative rather than the good and positive.
I feel much better now that I blew off some steam and will spend the remainder of the evening looking at the less replied to posts.
Well, speaking just for me, I’ve read and posted on two of the three “How To” threads because they’re just so darn amusing. I suppose it’s a combination of the way the OP chooses to present the topics and himself, coupled with how others have responded. Maybe I shouldn’t find those topics so entertaining, but I do and apparently so do many others.
As far as those fewer replies threads, if I don’t think I have anything more to contribute than is already there, I don’t reply.
I found those “how to” topics rather interesting seeing the methods dates back to the 50s.
However…
I have used sectional track on several 6’ ISLs over the years because I found that was the better choice since there would be a lot of cutting and fitting with the same amount of rail joints if I used flex trax…
I use sectional track for fillers on larger ISLs with zero problems.
Think of this Atlas still make sectional “snap” track,Kato,Atlas and Bachmann makes the sectional track with road bed so,somebody is using it. or it would be dropped from their product line.
So,one man’s thoughts is usable by others.
This is what forums are for.
As far as the low count replies some times the question has been answered or I’m not sure of the answer.Somes the answer could be found with a simple .com and click to a manufacturers web page.
I look at most of the threads posted (unless they name a product or process I don’t use) and reply to quite a few. If somebody is showing a better way to do something or suggesting an idea which I find useful, I’ll acknowledge that if I can do so without simply saying, “Me, too.” If someone is handing down Stone Tablets from Zion, I may reach for my hammer and chisel, especially if they simultaneously trash something I have been doing for a half-century or so. The same goes for the posts announcing the reinvention of the square wheel. Knocking a few chips off the corners might help it roll better.
If I can’t contribute to the topic, whether with hard information, a reality check or a bit of humor, I bite my tongue and sit on my fingers.
Note that one person’s bad news may be another person’s good news.
For reasons perhaps best understood by psychologists there are certain topics that some people seem to get really upset over - even feel really threatened by. Using sectional track seems to be one of these.
Some others are:
Building a 4x8 layout.
Some of the O scale people get really bent over a track gauge of 1.25" (instead of 1.17").
Some years back S scale felt they had to change from .875 gauge to .883 gauge - that’s 8 thousands of an inch.
Using code 100 in HO scale
Not weathering.
RTR
For example - ask a question about building trees for your 4x8 layout and at least a dozen people will tell you why you shouldn’t be building a 4x8 layout. They apparently never see that the question was about trees.
Good point…Maybe they can’t see the trees because of that 4x8’?
Your other points are well taken but,boils down to choice the modeler must make based on his/her needs.
I wasn’t going to mention this but,I think it fits.
On another 1 x 6’ ISL I used 2 snap switches as a crossover…It worked fine but,I don’t recommend it because that “S” curve between the switches look like a Tooterville trolley crossover–whew!
Thankfully I was using a Mantua 0-6-0T I built from a kit and 36’ MDC cars.
I am not certain which “how to” posts you are refering to, but the other postsmight be for a topic that I know nothing about, or can contribute no more than has already been posted. I am actually amused sometimes that after a question has been answered very well that people will still continue to answer.
Since our hobby has no hard set rules then by whose standards do we judge a answer by?
Just because you or I may think the answer is wrong may not make it so if we lack general all around knowledge and that type of knowledge doesn’t come by a article or book written by a “expert” but,must come from first hand knowledge based on hands on experience.
Our hobby is so simple a kid or newbie can build a simple 4x8’ layout and enjoy it for years.
Actually there are some fairly rigid rules and guidelines although they evolve and are not set in stone. The NMRA standards are one (but not the only) example. Before they developed their standards and manufactures largely accepted them very few products from different companys would play well together.
What you say is true about modeling techinques, materials, even what elements make a good track plan and philosphy of running/operating model trains. Before one strikes out on their own it is a good idea to know what the “experts” say and understand their reasoning. They can steer one toward good practices and away from things that really won’t work. One has a better chace if succeeding if they have some idea of what has worked for others. Determining who really is an “expert” is often difficult.
I have seen numerous cases where there are really correct and incorrect answers especially about the prototype (answers about prototype locomotioves and cars are prime examples) , and also about model railroad products.
Again looking at the very basics of the hobby anybody can build a simple 4x8’ layout without advice from “experts”(which begs the question who made them a “expert”?) so,again there is no real need to complicate the hobby by listening to those so called “experts” that may flip flop on their teachings.
I found several truths about this hobby over the last 55 plus years I’ve been in the hobby and there’s two that stand out…This hobby is as complicated or as simple as you want it.
I agree I seen some railroader wanna bes and operation “experts” answers on a switching that required several unneeded moves.I seen some answers that would get the conductor and engineer fired.
I’ve seen some modeling replies so complicated I had to laugh.
Speaking for myself and my replies in the "How to series…
I am not 100% certain I understand exactly what problem Sux is trying to solve. Most of my comments are aimed at figuring out the problem that requires his solution. I assume his problem is unique, since he is not using conventional methods, and I’m trying to disect what that uniqueness is.
So far…the best that I’ve come up with is that he doesn’t want seams in his grass mat scenery, but he hasn’t acknowledged that drives his method.
As far as the number of posts…
I think the reason there are so many replies is that his basic concept is very simple. Tracing, cutting, and gluing really doesn’t go much beyond 4th grade art class; so almost everone already understands what he is doing. Many people understanding a topic leads to many replies, both positive and negative.
Contrast that with the more specific posts you feel lack replies, and it may just be a function of there not being that many folks who feel confident about their knowledge of the topic to offer a comment, so the thread receives few replies.
I’ll agree folks reply to questions they have the most experience and interest in but the “flaming posts” tend to attract those that like to see a good argument keep going and won’t allow others to have a differing opinion.
My preacher once told me the best way to end a confrontation as well as a tug-o-war is to let go of the rope.
There you have a point, combining knowledge and interest with passion and then you get your “flaming posts”. And those subjects are pretty well identifiable, such as Internet sales vs LHS, 4x8 layout, DCC vs DC, Sound vs NonSound, death of our hobby, how to keep the hobby growing,etc.
I have not read any of the How To posts but I’m sure they will help some. Keep in mind that at any point in time there are usually only 30 to 50 people online here. Several are very helpful and hopefully that will increase the number of those actively online.
I agree with those who say this hobby can be as hard or easy as you want it. I also agree that there are some legit right/wrong answers and I don’t like to post when my posting adds little. Only so much time in a day.
And yet some people get all bent out of shape because the new to model railroading person did not use the search function. It seems like they cannot win.
Actually many newbe’s do start out with advice from one or more “experts” For instance my first serious HO modeling started in the very early 1960’s with with Atlas sectional track and Atlas plan books (many of the plans 4x8 or smaller) written by John Armstrong. Many Model Railroaders still start with them or with published plans by other “experts”. Armstrong’s Atllas plans are a good start and have the advantage over many other published plans of being buildable.
While there are many who many who strongly advocate against the 4x8 footprint, there have been many excellent 4x8’s built in the past, being built currently, and many will be built in the future. It is often said that the 4x8 results in poor space utilization, but depending on the space available this is not always true.
I am considering building a 40"x76" N scale layout (accessable from 3 sides) to fit on the upper bunk of a bunk bed in a 12x12 room. Because of book/display shelves on 3 walls and a work table, an along the walls plan is not feasible. The plan is based on 4x8 HO plan from a 1950’s Boys Life magazine. Based on a much posted rule of thumb I should be able to run 80’ cars, although appearnce will suffer because of the tight curves.
