Modeling concept
I decided to freelance a shortline based on local area. My concept is to model “time modules”. The idea came to me because I wanted to model a history of my shortline, which would mean updating loco’s, but then after I update that would leave me with say an old 2-6-2 steamer sitting in the box because it no longer fit my shortline after it dieselized. Then I have a waster loco. The concept is to model different times in different modules. I plan to start out in the mid 50’s with the GP9 I already have. The next module maybe a back date to say early 20’s with a steamer when the shortline started out. I think this is a good idea because then each “time module” can be run at the same time, so no waster loco’s or rolling stock. Plus I think it gives me a little freedome. If I’m visiting the LTS I shop at (I prefer to use Local Train Shop because while there are ‘hobby shops’ around there are also a few hobby shops that deal with model trains only) and see a really nice ACF cylindrical hopper I can get it with out worries of it fitting in my time era. The same can be said of engines, which is the most important part of me. I like the old 8 wheel drive steamers, ALCo road switchers, the first gen GP’s, and GP’s and ALCo’s from the mid 70’s. If I stuck with one specific layout in one specific time era that means I would never use these engines, or then have to update everything to fit, or just use them and be unprototypical. Plus like I said, this means after updating rolling stock you would no longer have to put away your double sheathed box cars once you reach say the 50’s. All you do is build a new module based in the 50’s.
But, there is one draw back to my concept. I live in an apartment. I also realized through all this thinking that in a small room, time era’s would have to left out, and only a small representation of that module’s time era could be modeled. It would be much more suited for someone has a larger basement to use, or even a club layout. Say for example large
If you like train equipment from different eras and don’t have room maybe some wall mounted display cases with the eras labeled would satisfy your itch til you have room for a layout. Also your models that don’t fit the current era on your layout can still be on display. I have a mix of deisel and steam models ,and right now the steam occupy the layout. BILL
My layout is dual-era. I have structures that would be at home in the 1930’s or the 1960’s. When I want to change timeframes, I swap out the trains and the automobiles.
I’m still thinking about a few structures which need to be swapped out. I’ve got a movie theater that’s too modern, but I found an old hotel kit that should fit in the same space. Likewise, the more modern oil tanks will be replaced by an old outdoor skating rink.
