Bought used 6-12917 switch tower. Has 4 ea. connector clips, all in a line, titled AC Power, AC power, Action, and Light. A wiring schematic molded into the base of the unit shows connections to be made between the second AC Power clip, Action, and Light. When bench testing the unit, I had to connect power to the first AC Power clip to get Action and Light to operate. I took the base off the switch tower and discovered o the second there was no internal wire connected to the second AC power clip. I have searched the internet for a photo or schematic showing the internal connections but have not located either. Would you happen to have such a schematic? If not, would one of you be so helpful as to post a photo that shows where the second AC Power connects internally? I would be most appreciative.
A second question regarding this unit if I might. After getting the internal wiring straightened out, do you know if it is possible to make external connections to operate the light off a accessory transformer and separately operate the Action function using an isolated track?
Many thanks, Swede
