So now, in addition to the already time-consuming brake tests, one would have to add a trip along the length of the train to be sure the lights are turned off in the middle of the train (both ends of every car), and only the device that is actually at the end of the train is turned on.
Why not just keep the current EOT devices with their air and electronic connections with the locomotive, and have red reflectorized patterns on the car ends (similar to the yellow or white on the sides), eliminating the need and expense for photovoltaic cells.
Perhaps something along the lines of GPS might be more cost-effective.
Why mess with a good thing? It’s a boxcar, not like it really needs to be that modern with solar pannels and lights and everything.
Once you’ve got a proven machine, the next logical move is to make it more productive (look at the evolution of the diesel locomotive.) Find a way to make a cheaper, stronger, lighter and more durable boxcar, and you’re set. However this isn’t even that big of an issue right now as specialized cars like coalporters, covered hoppers and auto racks are in much higher demand right now than the boxcar.
The photovoltaic panels would charge up batteries that would power the Light Emitting Diodes whenever the light dims. Two different color diodes would illuminated depending on the direction of the train. No need to turn them off. They would increase visibility.
Those photocells would last about 30 seconds before a forklift hits the underside of the roof and blows them off, or they get fouled by coal dust, rock dust, sand, trees, etc.
As pointed out, what about cost…an EOT costs 3 or 4 grand. Add that cost to each car, and you’re talking millions, plus the added maintance costs.
What do you do when the device fails? You’d have to switch the cars around to get a good marker. EOT’s are suppose to be dump tested before leaving the intial terminal, they also need to be calibrated once a year. Could you image the logistical nightmare of having to calibrate every car every year.
The company I worked for made communications equipment for the Mercury, Geminii, and Apollo space craft, as well as the Space Shuttle and other things that had to endure the “G”-forces of rocket lift-off.
They got into the business of RR-car telemetry and to be sure the equipment would withstand the rigors of the RR, they outfitted some RR-cars with “G”-force measuring equipment. Most of the measurements went off the top of the scale… the equipment was not designed to measure such high magnitude shocks!!
