How many of you out there have painted newer cars and engines for fallen flag railroads when they wern’t arround long enough to get them (or better yet, older equipment decorated for modern rr’s)? As an example i’ve seen several photos of widecab Rio Grande engines people made, and i’m working on some MP stuff (haven’t been able 2 post photos but i’ll try this one):
How about you? (if your not worried the “proto police” may hound you [:-^])
then…assuming Flickr will allow hotlinking into forum threads, you should get this:
ah! it worked…
a link to an image should always end in .jpg (or .gif or a few other image extensions.) .jpg being the most common. if you dont have that .jpg at the end of the link, you cant use the IMG tags to insert the image directly into the message…because without the .jpg at the end, you have the wrong link.
if you want to post the link, just dont use any tags at all…just copy and paste the link to the page, like this:
yeah im waiting for southern pacific to get old enough to try this, but the layout im doing is if the SP took over the UP, so UP would be patch in grey and white[:D]
I’d like to have an SD 90 or AC 6000 painted up in the old Chessie System blue/yellow/orange scheme.
I like the old F units painted up CSX, but I guess that was a real scheme.
I think what he means is more of the UP with the nose sporting a scarlet block and SP on it. Someone has a picture of that they customed.
Personally, I’d rather do a C&O. But I can’t seem to figure up where it doesn;t start looking like CSX. There’s a cool Monon SD-70 or something running around the MSTS add on site.
I rhink they call these foobies. But I have no idea why.
I believe it was T55 that had a run of something called the Classic Concept Series. I recall a Black Widow widecab (can’t recall exactly what it was) and a couple of other schemes. I found it interesting that there would be enough of a demand for something like this to actually produce it.
But I may rarely letter a non-Southern Pacific car “Southern Pacific.” All mass model manufacturers of rolling stock do this (letter a car the prototype never owned) routinely without warning the consumer. If there is an exception, I’d like to know. (I’m not talking about low-volume specialty manufacturers such as Westerfield and Sunshine.)
Here is an example from another website of what I’m talking about:
Byron Lane wrote:
I’m a little bit confused. There is a photo of SP493418 on Lee’s site > under H-100-9R that has quite different end walls than Tangents model > of SP493418.
Byron, the SP cars of Class H-100-9 were NOT center-discharge cars. They cannot be the same as the Tangent model, regardless of how Tangent has painted their models.
Tony Thompson Editor, Signature Press, Berkeley, CA
Go to www.atlasrr.com and search for “fallen flags” or “fantasy” or “fantasy paint” and check them out. There are great ones on there like The Rock,Southern and different freelance roads. Really nice and worth your time to check out.
