Layout constructed for a 100 degree (F) temperature range, very low humidity:
Scale, HOj (1:80) using American 16.5mm HO track gauge and NMRA standards.
Basic benchwork (C work like L girders, joists, risers, ‘rain gutters’ for some runs of straight hidden track) is built of steel stud materials.
Subroadbed is thin cookie-cut plywood with riser support on (approximately) 16 inch centers. Any tendency to warp or ‘roller coaster’ is controlled by screwing angle iron to the underside, sometimes across several risers.
Roadbed is sculpted fan-fold siding (or not sculpted, in the netherworld of hidden track.)
There is a full size cardstock track template caulked to the top of the roadbed. This allows positive location of the flex track at every tie end, not just at the nailholes. Since the low extreme is still above zero (F) latex caulk has no problem. The same caulk is used to anchor the roadbed to the subgrade.
Flex is laid with expansion gaps at every joint. Jumper wires around the joints assure electrical continuity. They butt solid in August, and open up to about 3/32" on a cold morning in January. Leaving inadequate space when tracklaying at moderate temperature WILL cause caulk failure when the oven reaches a maximum. (Don’t ask how I learned this!)
All specialwork is hand laid on wood ties, caulk, card stock, more caulk and foam. No problems to date with things not wanting to stay put.
I run the old fashioned way - the only microchips in the layout space are in an FM radio usually tuned to PBS. The temperature range doesn’t give plain DC control any problems, the ancient power supplies work fine and the locomotives don’t seem to know (or care) whether it’s twenty or one hundred twenty in the layout space. (The operator does, but that isn’t the question.)
If I was facing a problem keeping electronics alive at Antatctic temperatures,
