That sounds reasonable to me…I am planning on building mine in the same method. I don’t want to be fighting to get my big hand inside the roundhouse to install the rails once it is built. Are you building 4 different roundhouses? That must be a HUGE layout!
Don yes I am. I am sure glad to hear that someone else thought about getting the 0-5-0 in there after it is built. I have some pictures of the track work on the website under my signature.
Town one (Ashley) has a modern roundhouse with an Add-on kit for two bays for 2 Big Boys. Also the in tha same wown is the Original Roundhoue kit for 13" units that gives me ( bays in Ashley. This also has a 130 ft TT
Town two (Nanticoke) has the Modern roundhouse alng with the add-on kit for a Y6b and and a Challenger. This town also has a diesel shop and the 130ft Turntable.
Claycts…your on the right track,(pun intended) Im glueing the rail in first so that it will adheare to the plastic. If using CA glue you might try having a fan blow the fumes away as you glue up your windows, prevents fogging…John
CA fumes can/will fog clear plastic used for windows, so if CA is used inside any enclosed structure it should be left open a good long time before installing any windows, to allow the CA to completely cure. Or just don’t use CA at all, if it can be helped.
