i was looking through all my model RR books and magazines when i found a picture with a track layout that fits exactly what I’m looking for. But with my methods and very limited imagination i couldn’t make it fit. so does anyone have any ideas on how to make it fit without mutilating and deforming it too much? its a module by the way. okay, the module cant be longer than 5 feet long and the main line starts and ends 12in from the back all other tracks can be any where but no curves tighter than 12in radius i also like how the main curves near the TT. also the front can be any shape but no thicker than 30in.
Assuming you are in N scale, the answer is probably no. The picture is several square miles in size and would cover a 10 x 20 ft area in N scale if you built it full scale.
You will not fit it into a 2.5 x 5 ft area, without huge compromises.
Also look before you leap. While it looks very picturesque, its not all that great of a design. There is no siding or run around that I can see. It has a large engine facility, but no yard.
