I haven’t been on the forums in about a month, so I hope everyone had a pleasant holiday season.
I have more than a few railroad questions on varied matters. Any help you could provide would be more than appreciated.
Here they are:
1.) On TWC territory without ABS, is it possible to run a train and then run a following movement while the first track warrant is still in effect, and if so, how?
2.) On old timetable-train order non-ABS track, the brakeman is supposed to drop flares if the train falls behind schedule. As I understand it, a following train which encounters a lit flare should then proceed at restricted speed. Firstly, how far behind schedule must a train be for a flare to be dropped? (I.e., you wouldn’t drop a flare if you’re three seconds behind schedule, but would if you’re thirty minutes late.) Secondly, how and when does the following movement learn that it is safe to proceed at normal speed again? Finally, what is to protect a train if it falls grossly behind schedule before it gets to the next timetable point where a time is listed.
3.) What is the difference between an F7 and an FP7?
4.) I guess I missed this somewhere along the line, but could someone please give me a brief overview of the merits of DC vs. AC traction motors?
5.) I know that UP 3985 is the largest operating steamer, and that SP&S 700 is the third largest. What’s number two?
6.) Does anybody know a website which lists specifications of Alco diesels?
7.) Is there a system or rule of thumb for the spacing of staybolts and fusible plugs on a locomotive firebox, and if so, what?
8.) A couple of questions about modern GE diesels: What is the full designation of the locomotive commonly refered to as the DASH-9? I have heard C44-9W, GE-9-44CW, and a few others. What does the C stand for? Also, what are the external visual differences between a DASH-9, AC6000CW, and an AC4400CW, if any?
9.) If I’m looki
