More TMCC questions......
Couple more questions for those “in the know”!
First is…I just purchased an SC1 switch & Accesory control unit for my layout. Can anyone tell me what is involved with connecting my fastrack switchs to the unit? And also, I mainly use conventional motive power. Will I still be able to use the add on features of the TMCC componats even though my Powermaster is set for conventional mode. I understand that the powermaster is only controling the track voltage and the other unit is controling the remote control features.
Next is what about adding sound to the tenders of some of my steam engines. Is this “doable” since they are running in conventional mode? If so, which sound units should I persure?
Finaly, I understand that there is a module that will “remember” a particular run profile for a given engine as it makes a run so that the run can be repeated. If this is the case, again, will it work for conventional operating motive power?
As usual, thank for all you advice folks! You have been a very valuable source of information as I move into the world of TMCC.
Do you have a Command Base? You don’t need that component to control conventional loco’s with a PowerMaster as CAB-1 can talk to PM’s directly. All other TMCC components need the Command Base to receive the radio signal from the CAB-1 and turn it into track based RF signals or use the serial output port on the Command Base. There is an excellent set of on line tutorial’s on TMCC at the following web site: www.coilcouplers.com/tmc/tmc.html
