More Trestle Questions
  1. Is Stripwood better and harder than Basswood? Height will have 7 Bents of 12’3" each
  2. This is a curved Trestle. Do you spread the ties on the outside of the curve or make the top larger to accomodate the track?
Thanks in advance for your help.
A lot of stripwood is basswood. Balsa is also used and cuts nice but is a little soft for a trestle.
The ties are all slanted a little. If you use one of the flrx track bridge tracks, it all works nice. The ties are closer together than regular track and a little longer.
