The main advantage I’ve found from using the hair spray as a sealer is, if you really mess it up, some work with running water and an old toothbrush, you are ready to try again.
As long as you didn’t use a water based paint for the brick color.
Another advantage is the cheap stuff seems to work best. And a big can does a LOT of buildings.
ukguy:
Looks awesome. Can you please post a picture of the finished building when it’s done. I want to look at the final result.
I have an assembled building in the basement, er, train empire room that I haven’t put window glazing into yet. Heading down as soon as I post this and give it a try.
This is a good tip, another advantage is that the wife will be pleased if she see’s me working with flour, I’ll have to bake a cake.(or buy one).
Your brickwork looked great, just as I would like it.
What kind of icing are you going to use? I vote for chocolate. [(-D]
Ok chocolate covering, a three tiered cake with squashed pears and fresh whipped cream between each layer. Any flour left over can be used thanks to ukguys great tip.
