I am putting together a carnival I pick them up a few years ago. Where can I buy motors and gears plus they had some kind of band driving them I tried rubber bands put can get the wright size. Any help would be appreciated.
Thank you for your time.
I bought the parts in the very first link You posted…just for the cog rail that the scratch/bash bridge needed to lift it. All those parts are very finely made without any flash. Also used many gears from them also for the bridge. I recommend them.
Take Care![:D]
Frank
The cog rail is sandwiched between the two truss girders (pointed down) that are pulled into the control tower with more gears and two electric motors.
I’m working on an animated figure for a bedroom in one of my scratch built homes. I‘m using a small piece of the cog rail to rotate the figure as it moves around the room.
Your right about the precision of the gears, the quality is excelent.
I have a 20 RPM gear motor on order but its not due until December 20th. I put together a couple of gears with a 3.7g micro servo and it works pretty good.
Mel
