Hi everyone, constucting a mountain and was wondering if anyone had any luck using either of these two types of mountain building techniques. If you know where to buy the ingredients or how to put it all together,it would be greatly appreciated.
I built my mountain [w/MesaVerde], tunnel, and elevated tracks using a 50-50 mix of concrete and mortar mix over 1/4 in. wire mesh. The track roadbed is ladder conctruction with aluminum wire screen over it to hold ballast in place. The :Y: formed goes to the right into a 5-track covered siding.
Hi I am using a rough wooden form that I cover in chicken mesh then using a cement that has been coloured with cement die in a creamy mix .Having previously soaked in water , wash hemp sacking in the mix untill its loaded . Place the layers upon the mesh and allow partially to set in sheets 2ft by 1ft to build up strength . When partially set smooth more mixture on to form your shapes and textures and brush with various items like rough ends of wood , stiff hand brushes to make it all look natural . I use waterproofing agent in the cement mix to stop frost attacking my mountains and an installing a frost stat and greenhouse heaters in the mountains to help them through snowy winters ! I would post some pictures but am computer illiterate so do not know how that works
