how many of you have ever mounted ditch lights on your locomotives?..I have Athearn locomotives and need some tips on mounting them so that i don’t make a mess of the engine fronts…what parts do you use?..will grain of rice bulbs work?..any information on this subject will be very helpful…thanks!..Chuck
Details West do a selection of Ditch lights in white metal for mounting both on the top of the walk-way and on the front below the anti-climber they need to be drilled out to suit the bulb size but it works well and they come with instructions for drilling the mounting holes in the right place.
thank you brother…it’s going to be awhile before I do this project and want all the info i can get before starting…Chuck[:D]
What kind of loco are you mounting them on? I have an Athearn SD40-2 that I would like to add them to also. I’ll have to check out Details West’s website for those kits.
Good Luck
Greg
i’m going to mount them primarily on AC4400’s, U33c’s, SD,50’s, GP 50’s and GP 38-2’s
I’ve always thought ditch lights are best modeled using fiber optic, much like this:
http://www.thefiberopticstore.com/Projects/John-FO-Loco/Train-Misc.htm
Here is a discussion from our very own board this past April about fibre optics and locomotives:
http://www.trains.com/community/forum/topic.asp?page=1&TOPIC_ID=13008
One bulb (well, one LED), two lights - very nice. Only problem (and a big one) - add-on ditch lights that rise over the anti-climber, as opposed to the ones mounted on the pilot/anti-climber (very straight shot running cable to the latter, as opposed to annoying bends for the former).
