I’m using 2" foam as a tabletop without a plywood base (just joists every 12-16"). If I use tortoises, can I mount them in the foam (by cutting a square hole) or will this weaken the foam board too much and cause it to sag? I’m particularly concerned about doing this in the yard where there are a lot of turnouts in close proximity. Does anyone have any experience/advice doing this?
Brad
