I just spent ‘hours’ trying to program the address into a new Athearn MP15AC with Sound/DCC. I could not get it to program on my DCS100 program track. I took the engine to a friends house today(he has a DCS100 with a program track ‘booster’) - Still no luck! I was going to try programming CV17/18/29 ‘on the main’, but decided to try using ‘ops’ mode programming ‘on the main’ as he had no other engines on the layout. It worked! After some other programming, I got the sound levels for the horn/whistle lowered and changed the acceleration. The reason we tried ‘on the main’ programming was that there would be full power there. As a side note, the MRC decoder does not support CV ‘readback’; which may be why it could not complete the 4 digit address so I could key in the ‘y’.
This is the first decoder that I have had trouble with(I know, I have read all of the Genesis/MRC issues, but the price was too good). I have programmed hundreds of BLI/P2K/Soundtraxx/Lenz/NCE/etc decoders and have never had a problem. Trying to program using my DT400 throttle or Decoder Pro failed with normal ‘paged’ mode. I can understand the frustration many folks have with the MRC decoders, and I am sure most of them do not have the ‘programming tools’ that I have available. I amazes me that Horizon/Athearn can produce a ‘premium’ great running/well detailed engine and not put a ‘premium’ decoder in the product. The engine is now running fine, but I suspect that the average modeler would just ‘return’ the engine when the normal address programming fails. I would not expect most folks to get into exotic CV programming(many of the low-end systems cannot even access all of the CV’s).
Jim Bernier
