MRC 2000 COMMAND CONTROL
LOOKING FOR A LITTLE ADVICE…I HAD A WORKING COMMAND CONTROL 2000 UNTIL I UPGRADED THE POWER SUPPLY. INPUT REQUIRES 14-20 VOLTS AC OR DC. I DIDN’T REALIZE THE SUPPLY I WAS ADDING PUT OUT 25 VOLTS…RAN FOR A SHORT WHILE THAN ALL I GOT WAS A SHORT INDICATOR BY VIEWING THREE SOLID LEDS !! REVERTED BACK TO OLD POWER SUPPLY AND STILL SHOWED THE SHORT EVEN AFTER DISCONNECTING FROM THE LAYOUT. I OPENED THE COMMAND CONTROLLER, BUT NO FUSE OR RESET…DOES ANYBODY HAVE AN IDEA AS TO WHERE TO SERCH FIRST FOR BLOWN CAP/RESIS ETC ?
First, please stop SHOUTING !!!
You have probably blown one or more of the output transistors.
WELCOME ABOARD!
