OK, before I rip it out and throw it in the trash, how do you reset the decoder. (No I don’t want to use a 2 pound hammer)
I bought a NIB MRC F7 A from my LHS on the cheap. When I saw it had a decoder I knew it was going to need to be replaced. Decoder Pro could not read the decoder. I tried to run it on the main using address 3, nothing.
Since your using JMRI, use it to reset the decoder (if this model supports reset).
Open the roster file for this locomotive while in service mode (programming track). In the top menu click on ‘reset’ followed by ‘factory reset’. The rest is intuitive. This writes to the appropriate CV to reset the decoder.
Note: This is NOT the same as the ‘Reset to Defaults’ button on the roster entry pane. That just changes the CVs to the defaults in the decoder file which may or may not be correct. This then needs to be written to the decoder
(you probably will not be able to read back that decoder…so do whatever you have to do on your programming track with your DCC system to ignore the “cannot” read CV message that will come up)
This might be a REALLY old MRC decoder - if so you need to use Register Mode to progrma it and it has VERY limited settings. This is the way many decoders were back in the early days of DCC, but most quickly moved beyond that. MRC keps makign decoders way down on the low end for much longer than most - or maybe they just had so many made they had to keep sellign them. Plus the early MRC DCC systems where highlky limited in themselves so it didn;t matter too much. This is all bfore they made their sound decoders.
Do the instructions tell you exactly which MRC decoder is in that engine?
Looking at the MRC website manuals for discontinued decoders it appears that some of the early decoders did not have a provision for resetting. Try just setting CV 1 to 3 and see what happens.
I suppose you could try resetting to the factory defaults, assuming that it was an early decoder with only a few CVs. Here a link to what looks like a 2003 decoder instruction. Try setting CVs 1, 17, 18, and 19 to the values shown.
