MRC Extension Boxes for Prodigy Advance
I would like to use Extension boxes for Prodigy Advance, it comes with one cable and the diagram shows a serial connection. My question, if I want two controllers to be used at the same time do I need extra cables and y connectors so that I can run two sets of wires to each extension box?
Thanks!
Hello Raybo
If I understand you correctly no, that cable to the extension box from the command station is all you need, you only need another cable if you want to add another extension box to that one. Natuarly you will need a cable to each handheld, but you can plug two of them in the same extension box.
Hope this helps.
Den
Go to
You may want to post this on the MRC Yahoo Group site. Maybe someone there can help you.
http://groups.yahoo.com/group/MRC-DCC/
also while there search for special price deal for members of this user group by the President of MRC on Extension Boxes .
MRC President at times reads the posts on this site
Thanks to both of you for the help
There have been a lot of recent postings on the MRC Yahoo group about building your own extension boxes, something I’m going to look into myself once my move is complete and layout back in place.
That 2nd port on the back of the expansion box is so you can daisy chain to the next expansion box. I dont recommend ‘closing the loop’ back to the command modual…
David B
