My son needs to upgrade to a much more advanced DCC system. It’s for a 5x11 foot layout and he runs more than 4 loco’s at a time. Here are some of the things he would like to be able to use:
Number 2 of your list will eliminate most of your starter systems such as the NCE Power Cab and the Digitrax Zephyr. Running wireless will also eliminate the Lenz systems unless you add the Easy DCC for Lenz wireless throttles. So the options you have with the criteria you list will be the NCE Power Pro R and the Digitrax Empire Builder radio. Both of these systems will do more than you will ever need. Both are easily expanded on and will give long time service.
With the MRC system the hand controller is also the command station. If something happens to it (dropped) the whole system is down. With the others you will still be able to operate on another throttle. Adding another wireless throttle will cost as much as the whole system. Engineer throttles on other systems are less than half the price as full function throttles. You can add wired throttles to the MRC system as you can with all other systems.
If you would like walk around wired systems then choices are limitless. Lenz, NCE, Easy DCC and Digitrax all have great systems for a whole lot less money.
When you say “4+ loco’s running on layout”: Are they separate locomotives, or are they sets of consisted locomotives? Personally, running, controlling, and keeping track of two locomotives (or two consists of locomotives) simultaneously on a smaller layout is about all I can handle.
Actually, Pete, that’s not true. You can add wireless to a Power Cab or Zephyr; it’s just generally a more expensive path to take than purchasing a wireless system from the get-go. You could add a radio base station and a wireless throttle to both and be up and going.
I was trying to be more cost effective for the basic requirements the op put forth. The Power cab has only a recall of 2 locomotive addresses and I am not sure how many the Zephyr has. With 4 to 5 locomotives running at once in separate trains being able to recall addresses quickly would be a paramount concern. Having a more powerful system right out of the box would be an easier learning curve than immediate expansion and additional components needed. The PH Pro R and the SEB R exceeds the basic 4 requirements without additional pieces. Plus the OP would not have to do any upgrades until they are ready for them if needed at all. The Zephyr has twice the power of the PC but adding the smart booster will help. The OP did not specify if lighted passenger cars will be in any of those 4 to5 trains. Just 4 of the Spectrum lighted passenger cars on my layout robs almost a half amp of power from the system.
If either of those other two was using JMRI for programming that eliminates the MRC.
If he already has an Apple device or an Android phone or tablet, and a wireless router in the house, than wireless control can be added to just about any other system for the cost of that system’s computer interface, NCE, Digitrax, Lenz, CVP all support JMRI.
If one of the other things was adding detection and signalling, Digitrax wins hands down. None of the others have an as capable control bus, and there are tons of third party compatible add-ons.
I would have agree with Randy. The MRC Prodigy Express has a very expensive upgrade path. And with NO capability of adding JMRI in the future - it becomes a ‘dead end’ system. Many folks get tempted by the low discounted price of the Prodigy Express. A friend has had one for about 3 years. He has really gotten used to using JMRI at the club to program his engines, and really cannot do this at home. The LCD panel on the throttle is starting to go out and the repair cost is almost as much as the system.
I gave him my old ‘Zephyr’ as long as he got a DT4xx throttle. He is getting a wireless throttle and receiver and I will help him install everything after he returns from vacation. The Digitrax Zephyr is an entry system that is ‘full featured’. The ‘built-in’ throttle is sort of a turn off, but I have never used it! I bought it from a LHS that was going out of business about 6 years ago, and have used it for programming upstairs in a spare bedroom/study.
Thye NCE Power Cab is another good option - at least it has a good upgrade path, and you can use JMRI with it. I have used it, and it is a nice system. Like all other NCE system, there is no ‘analog’ mode to run DC engines. Since it comes with a ‘Hammerhead’ walk-around throttle, you already get a good super throttle in the package.
I would suggest sticking with either of the 2 big DCC players in the US market(Digitrax or NCE). It will money well spent.
Buying a good DCC system is a big deal for most of us. I have to agree with Jim in his post about getting either a Digitrax system or an NCE system. In my opinion, the NCE system is more user friendly, but you should take a look at the manuals of the systems that you are considering. Both NCE and Digitrax have web sites where you can download the manuals of the systems you are considering, and read them.
I would have a tendency to get him the NCE Power Cab system to start this year. Next year, or for his birthday, you can start adding parts to it. Either the radio stuff next or a smart booster (adding more power for more trains), then the other part next time.
Although with the NCE system you only have two locomotives in the stack that you can toggle back and forth to, the controller can select any locomotive that you want to run. Each locomotive would have a DCC decoder installed in it, and should have it’s address programmed to the locomotive number on the side of the cab. That way you know what locomotive you are choosing.
If there is a hobby shop that specializes in trains near you, going there and looking at the different systems may help, but not always.
Still pricey but looks like a one and done system for what he needs. I have to say I love the dial for speed control rather than buttons but I don’t think we have enough experience to make that judgement call.
NCE is getting ready to ship upgrade eproms. For me, my Power Cab will have six recalls. No idea what the Power Pro upgrades will be or when the systems will ship with the new upgrades.
If NCE is what you’re leaning towards, the Power Cab would be a start. Cost: $150, discounted. If you need more power (increase from 1.7A to 5 A total output) you can add the Smart Booster (SB3a). Cost: $130, discounted. Click on the link to my web site below and you can read the initial reviews I wrote for both the Power Cab and Smart Boosters (SB3 & newer SB3a). It includes pictures and lists the features of each.
BTW, Rob, I used to prefer the “knob” too until I got my Power Cab. I find that I have MUCH better control with either the fine/gross speed buttons or the encoder wheel than a potentiometer (knob). I can also do it one-handed.
Yes, TTE can do that sort of thing for you. Tim Smith @ Empire Train & Hobby above is also very good and very reasonably priced. It’s worth contacting both.
FYI: Tim and NCE are on the same road in the SAME town of Webster, NY about 1/10 of a mile from one another
