Is the cab plugged right in toi the base or do you have extra cables and panels? Try plugging right in to the base. Also, does your model have the switch that sets for like 1-4 cabs and the other position for 5+ cabs or something? Is it on the lower setting?
The cab is plugged directly into the Base Unit, I do not currently have any remote panels. the Cab Selection switch is set for the low number so it is not looking for more cabs.
I’ve got a Prodigy Express system. The SaDa message come up when I have a short and I either have to power down or unplug the cab. This, while inconvenient, sounds like normal operation for the system.
In the meantime, what about resetting CV’s to lock out DC operation? That may help the runaway situation. Note: I haven’t tried that yet, I’ve been able to track and fix my shorts so far. But I’m planning on it when I go through and speed matchmy locos.
As a temprary fix/test, would you be against installing some switches in place of the reversers? Just thinking of eliminating a variable.
