MRC Prodigy Express vs Digitrax Zephyr
I have a layout that is about 18ft long by 8ft wide. I run no more than 8 or 10 locos at any given time. I am looking into a new controller. I am between digitrax, and mrc. I have heard good things about both. Do I go starter set, or go middle of the road ie, advance2, or digitrax’s step up from the zephyr and why??? Gracias mi amigos
The main thing you should be taking into consideration is expandability for the future, especially with as many locomotives as you say you envision running at one time.
I’m not familiar with whether or not you can add boosters to the MRC, but I know you can to the Digitrax system. The current capacity of the basic MRC Prodigy Express is only 1.6 Amps, which may be straining trying to run more than 3 locomotives at a time. The Digitrax Zephyr has an output rating of 2.5 Amps.
http://www.tonystrains.com/technews/mrc-prodigye-review.htm
Another system you might want to consider is the NCE Power Cab, which has 2 Amps output and is easily expanded. Prices for this system range as low as $150.00 if you shop around.
I would go with either a Zephyr or NCE PowerCab…for one reason, JMRI.
David B
From all I’ve heard, either system is good and is expandable. I have a Zephyr, I believe it’s power output will handle up to 11 engines or so…although if you run sound-equipped engines it would probably be less.
The MRC is expandable. An 8amp booster is available, and you can upgrade to the Advance2 or Wireless just by plugging in the new components.
PERSONALLY (and I emphasize that), I prefer the human interface engineering of the MRC units. Your mileage may vary.
WRT JMRI, MRC claims their proprietary software is easier to use. I can’t speak to that, never having used JMRI, but I don’t get in and monkey with decoder / CV settings all that often, so I don’t see that as either a drawback or a benefit. Again, others will disagree.
The second big reason to go Digitrax is Loconet. One single system bus for throttles, wireless interfaces, detection, and signalling. No one else has anything like that, with anything near the same capabilities. Plus there are plenty of non-Digitrax third party products that are compatible - from companies like Team Digital, CML, Logic Rail, and RR-Cirkits. And these products are featured on Digitrax’s own web site - how many companies do you knwo that freely acknowledge and even link to competitor’s web sites?
As for the computer interface, maybe MRC’s software IS easier than JMRI. But there are OTHER software packages out there besides JMRI - things like RR&Co, which is in many ways superior to JMRI when it comes to creating dispatcher panels and layout automation. Like JMRI, RR&Co works with many different systems - alas not MRC because they have chosen to keep their interface protocol proprietary.
My personal preference is Digitrax, but if you decide to go with Prodigy I would recommend that you not get the Express.
Whichever system you choose, think future expansion.
I definitely prefer the user-friendliness of MRC’s Prodigy Advance. If you get the newer Advance-2, it provides computer interface capabilities, and a wireless upgrade.
Digitrax is a good system, don’t get me wrong, but MRC is so intuitive and so simple to install and operate, it’s well worth a second look. When I got mine it took about 5 minutes to set up and get started.
Digitrax is much more customizable, but that makes it very complex to really understand. The one advantage it might have is that people who have been doing DCC the longest are probably using Digitrax. So there’s lots of people to consult with when you get lost in their very bewildering owner’s manual.
I tried using Digitrax and Lenz before I dove in and bought the MRC, and I have yet to regret any aspect of that decision.
As an aside, my layout is what you might call medium size, N scale, and I can keep my entire fleet of 40 or so locomotives on the layout at any given moment without causing a hiccup in the basic Prodigy system. I will ultimately be adding another power district, which is a simple matter of plugging in a booster and following the simple wiring directions.
My favorite aspect is the ability to toggle through as many as 25 locomotives or consists without going through a lot of riggamarole. Digitrax throttles require a fairly steep learning curve, and even then will only allow you to access two addresses at a time (at least that’s what’s obvious… you might be able to do more, but they make it quite a quite a mystery to figure out.). So, with my MRC, I can have two trains orbiting the layout, I can build a train in the yard, and even switch a local somewhere else on the layout all from the same throttle. I like that flexibility.
Every Digitrax set up I’ve seen looks like Frankenstein’s lab. Like I say, it’s a really good system that can be adapted to almost any situation, but if you are looking to just get started and run some t
I too was asking myself that same question when I converted to DCC last year. I was considering MRC, Lenz and Digitrax and settled on the Digitrax Super Chief. I am planning a major expansion ths year and wanted a more sophisticated system than the entry level Zephyr which does have some limitations. What really tipped the scale was the Loconet and the ability to handle everything through one bus - which i think someone said already. I had also heard great things about their customer service - which I can vouch for after returning a defective throttle - and I also found that their documentation was well written and quite clear. There is a real learning curve with their system and some minor drawbacks, some of which have been pointed out here, I have been very satisfied with the Digitrax system.
Pick which ever you like the best. Personally I have a Zephyr that has been heavily expanded. I would not trade it for an MRC system under any circumstances. I simply could not do what I do with my system with an MRC configuration of any kind. I have used an MRC, and it is certainly easy to grasp. There is more of a learning curve with Digitrax, but once you are familiar it is second nature and not at all hard to use. My kids use the system with no problem at all. Again personal preference, but I would not want a system cheaply made in China, with poor support, when I can get a US made product with a lot of local knowledge and support. Just look at the 2 web sites and see how much more tech support there is posted on-line. The Digitrax tech support depot is second to none on the web. The other issue for me is the companies commitment to DCC and how legacy users are treated. For me there is no comparison.
That’s about how long it took me to get my Zephyr up and running.
The older Digitrax throttles were not very intuitive(the biggest problem was they tried to do to many things with to few buttons, so you had to remember some odd button combniations), but most people who have actually used the DT400/402, Zephyr, and UT4 throttles find them quite easy to learn(the last “difficult” Digitrax throttle was the DT300, which Digitrax discontinued over 4 yeasr ago).
Digitrax’s DT throttles have a stack that can be configured for 4, 8, or 16 addresses, and accessing it is not a mystery at all, it’s in the manual under “Recall a Loco.” Something the Digitrax DT throttles do give you is DIRECT control over two locos at a time(the only other current system I know of that gives you this ability with a walk around throttle is ZIMO).
I have seen plenty of Digitrax setups that do not look like Frankenstein’s lad. I have seen some that do, but they often involve things like block detection or signaling, things that MRC doesn’t even have.
I’ve used JMRI extensively, for at least the past five years or so. When MRC came out with their claim that their software was easier to use, I downloaded a copy and gave it a try. I’ve since uninstalled it, so this is from the best of my recollection. I’m sure the MRC users will jump in and correct me if I’m wrong.
First, the MRC software can only be used for programming decoders, and some number of throttles on the screen. I don’t recall that it has separate templates even for the MRC decoders, let alone for other manufacturer’s products.
On the other hand, JMRI has templates for literally hundreds of different decoders, with more being added all the time. Within the limitations imposed by the decoders themselves, JMRI will attempt to identify the specific model, or at the least the model family. It then presents customized panels based on that particular decoder’s abilities. No template for your particular decoder? No problem, use one from the same family, or fall back to the default NMRA template. And if the “usual” programming mode (paged, direct, etc) doesn’t work well for a given decoder, JMRI allows you to pick any of the modes supported by your command station. I don’t recall if the MRC software has that ability or not.
Like the MRC software, JMRI also allows you to save roster entries with all the settings for a particular loco. But JMRI also automatically makes backups when you change them, so you can go back to the prior version if you inadvertently hose one up. JMRI also lets you group them (home layout roster, club roster, etc) for convenience.
