I just bought an MRC Tech 6 Sound Controller. I have never used DCC and this device works great with my Athearn, Walthers and Bachman sound equipped engines. However, it will not work in the Dual mode with my Blackstone K-27 #463. Anyone know how to get this to work with the MRC Tech 6? Blackstone said the engine was set to address 463 and that CV 29 had to be changed from 40 to 6. I tried this but it still doesn’t work in the dual mode. Can anyone help?
Did you happen to try your K-27 on DCC first, and did it appear to run properly in that mode?
I ask this because a friend of mine bought 8 of those things, and only one is working properly on DCC most of the time. Six of them are back at the LHS to be sent to Blackstone for repair, and the 7th will be packed up and returned shortly.
No, I have never used on a real DCC system.
I suggest that you do if possible. The word down in the lunchroom being spread by Randy Rumor is that the first run of these had a problem caused by the application of an incorrect lubricant containing graphite to the motor gearing which caused havoc to the electrical system. As I mentioned, 7 out of 8 purchased by a clubmember all had a problem. One ran about 10 feet and then quit running. Another ran intermittantly and acted like it had a electrical contact problem (wheels and track were clean), and I understand that a couple others were DOOTB (dead out of the box). So it would be a good idea to see if the one you have runs properly on DCC before trying it with the MRC controller. I’m not saying that the engine you have is a problem child, but no sense trying to fix a MRC problem if the issue is at the engine end.
Hopefully you got the engine at a local hobby shop and they have a DCC test track. I’m not particularly interested in narrow gage, but our club has a small narrow gage loop that I invested some time in this past year. I saw a couple of the K-27 on EBAY, one at a somewhat reasonable price, but was discouraged from attempting to bid on one of them due to the issues I mentioned above.
Regards
Or…the issue is that the K27 uses a high quality decoder and will not respond to the same signals that an MRC decoder will respond to…
In short, the Tsunami really wasnt designed with DC in mind…even though it will work with DC…just not as nicely as a QSI, for example.
David B
Could be, but at least one of the engines he has doesn’t have an MRC decoder in it (the Bachmann). The ads for the TECH 6 say that it will operate any NMRA compatible decoder, which I assume the Tsunami is.
I was only throwing out the possible locomotive issue as something to check before we went down the MRC product is the problem path again. I certainly don’t have your experience with decoders, so you could be correct. I was only basing my suggestion on the fact that of a sampling of the same locomotive, 87.5% exhibited a problem.
If the OP is lucky, a communication issue between the TECH 6 and the decoder will be the ultimate problem. Much better that than an engine problem.
I have not made this an MRC issue. The issue is that there is no NMRA standard for a DCC locomotives with sound and how it behaves with “Black Boxes” or DCC for that matter. Soundtraxx opted NOT to have their sound decoders respond the same way that MRC, QSI or BLI decoders do to little Black Boxes (which is what this MRC product is).
This is not an MRC issue, rather an issue that if the OP was using DCC he would have no problems.
David B
Thanks for all of your suggestions but I don’t think this is a motor problem because the engine performs flawlessly on my DC power pack and it works fine on the Tech 6 std mode (i.e., pure DC). It just does not work on the Tech 6 Dual Mode. In that mode it just gives the air compressor sound and won’ respond to any of the buttons. The Tech 6 must have the engine address set to 3 but the Blackstone K-27 has the engine number (463 in this case) as the address. I have not been able to change the address to 3 with the Tech 6. Does anyone know how to do that? Using shift-9-9 does not change it to 3.
I think you will need a DCC system to change the factory preset address.
The over-oiling problem is a vexing issue with this run of locos. Blackstone has been very good about fixing these problems. It is unfortunate that a loco this nice is spoiled by this problem. Not all of the Ks have this issue. BTW: I know several happy owners of these locos and most have had some problems with the over-oilng thing. Blackstone made good on all of them.
Guy
Ah. Then that is a different story. I understood from the initial posts that the engine was not running at all.
As far as I understand it, the Tech 6 needs the DCC address to be a specific one for the ‘dual mode’ to work. On most DCC systems, Tsunami decoders need a program track booster to program on a programming track, although you can program them in Ops Mode without such a booster. The question is - just how does the Tech 6 go about resetting the decoder address to the one it needs?
Is this maybe a case of not reading the instruction? The TECH 6 instructions are here: http://www.modelrectifier.com/resources/trainSound/Tech6%20addendum.pdf
An extract from the instructions are:
Locomotives equipped with N.M.R.A. DCC decoders:
Press the “Mode/select” button until the L.E.D. indicator lights up, showing that you are in the “DUAL” operational mode.
“DUAL” mode operation- This mode of operation is for DCC Decoder Equipped Locomotives only. There is a lot of information to be digested in this section, please read it thoroughly.
Note- all DCC equipped locos and decoders come from the factory set to N.M.R.A. default address # 3. This Tech 6 Train Controller will only run these locomotives and decoders on address # 3. If you were running your DCC decoder equipped locomotive on a DCC layout, and changed
Maxman, I have those instructions BUT they only work if your engine was originally programmed to have an address of 3. I guess I will need to take my loco to a place that has a DCC system and then reassign my K-27 address to 3 since it is currently 463. I was hoping I could use the Tech 6 to do this but so far no one has come up with a way to do this. I really appreciate all of your comments and suggestions. Neither MRC or Blackstone have been any help in trying to do this.
I think the easiest way would be to take it to a DCC equipped layout as you say. However, the instructions imply that you should be able to re-assign the loco to address 3 with the TECH 6 as follows:
Re-assigning DCC equipped locos to default address # 3 with your Tech 6 is very easy and takes only a couple of steps:
1- Place your locomotive on the track.
2- Turn on your Tech 6
3- Press the “Mode/Select” button until L.E.D. indicator shows you are in the “DUAL” mode.
4- Press the “Shift” button once, then press the “9” button two times, [SHIFT+9+9]. Both directional L.E.D.s will then light up.
5- Wait a 5 seconds, and one L.E.D. will turn off. When this happens, your loco is now set to default address # 3.
I don’t know if this will actually work or not, but give it a try if you haven’t already. If it doesn’t work, then I’d be giving MRC a call and asking them what the story is. Whether or not you get an answer to your question is open to speculation. Ask for a gentleman named Frank. I think he is their DCC expert.
Regards
Maxman, I have tried that numerous times but what that purports to do is reset the settings, including the engine address, to the factory values. That will only work if the factory address is 3. Thanks again for your suggestions.
Actually, MRC’s BlackBox and Tech 6 ARE DCC. They are single address DCC controllers(despite the fact MRC likes to claim that they are not DCC, how’s that for truth in advertising?), so Soundtraxx should respond to them the same way they respond to any other DCC system, as long as the address is ‘3’, which seems to be the problem.
Try following the steps below that to program individual CVs. Set CV1 = 3 and CV29 = 6. The automatic rest may assume a certain type of decoder (probably MRC) and the reset procedure for all decoders is NOT the same.
If it doesn’t work as advertised, then it appears that your only alternative would be to get the address changed on a DCC layout.
I would think, however, that the factory address should have been 3. But this would have been the short address. The active address would have been 463, but this would be the long address. Again, if you tried it and it didn’t work, the reset elsewhere option is the only choice. If you do reset the address, just reset it so that the short address of 3 is the active address. I’d leave the long address as 463 so that you won’t have to remember some other number later.
I talked and emailed with Frank at MRC and after several suggestions from him which did not solve the problem he has primosed to research the problem and try to find out what to do. If he solves the problem I will post the answer. Thanks again for everyones suggestions,
To be frank, the only answer is to buy a proper DCC system if you intend to be running different brands of sound decoders.
The alternative is to buy only QSI or MRC decoders that will react properly to the MRC black box.
The Tech 6, at 110 MSRP, you are very close to a good quality, expandable DCC system from NCE or Digitrax.
David B
