I have a new MTH 2-8-2 locomotive and I have an NCE DCC system. I programmed the short address as “3”. I programed the long address 4515 and activated the long address and deactivated the short address. I selected loco No. 4515 and toggled No. 3.
I can’t get the long address to work.
I must select loco 3 and toggle No. 3 to run the locomotive and it runs fine.
You can’t program the long address on the program track with the NCE system. In matter of fact you can’t program it at all.
We had a similar problem at the club with a NCE power pro. The solution is to by a program track adapter from NCE, and then buy a program track booster like PowerPax.
Just another of the gotcha’s of working on an MTH train on an DCC layout.
You do NOT need a Power Pax to program the long address of an MTH locomotive to set the long address. This is just another misconception / misunderstanding about MTH locomotives.
I too run my MTH HO locomotives with NEC. I don’t own one of the light Mikes, but I do own eight other MTH engines all programmed to with their cab numbers as their long address. Here’s how you do it…
First, you have to program CV’s 17 and 18 with the long address while the engine is still programmed to the short address. Since you failed to get the engine to respond to the long address the first time, it is best to assume it also failed to register the change of the long address to 4515. Do this first or you could loose communications with the engine and have to do a reset.
ALL PROGRAMING OF MTH ENGINES MUST BE DONE ON THE MAIN!
To program the engine place it on the main and make sure it will run as engine 3. Then enter the OPS programming mode on your NCE system by pressing the PROG/ESC key once and pressing enter. Press “2” to program the CV’s directly. Type in “17” and press enter to select CV17 . Type in “209” and press enter to enter a value of 209 in CV17. Repeat the process for CV18, entering a value of “163.”
Now you can safely program CV29 so the locomotive will respond to the long address. Follow the same steps above to enter OPS mode programming, select CV29, and enter a value of “34.”
Your engine will now respond to the long address of #4515 and will run at one scale mile per hour for each speed step.
So why not save yourself a lot of excess work and for the money you spent for the MTH 2-8-2 you could have bought 2 of the BLI versions with some spare change left over.
You could also probably have done the same with with a couple of brass ones as well actually.
Many thanks. I followed your instructions and the locomotive operates fine with the long address. The DCC instruction in the manual were not as understandable as your instruction.
I’m up and running now. I hope other folks who read your instructions benefit from them. Perhaps MTH should provide a copy of your instructions as an adendum in the manual.
I appreciated immensely your instructions for programming my MTH Mikado 2-8-2 locomotive, Baltimore & Ohio.
As I mentioned, my control/power system is an NCE wireless procab. In general terms, how do you lower the volume (e.g. whistle & bell) on a locomotive? For example, I have a Blueline 2-8-2 Mikado, Great Northern and the whistle and bell are too loud.
Also, I have a Spectrum 2-8-0, with Tsunami sound, but the whistle and bell volume is too low.
The CVs for changing the master volume level should be located in your Blueline and Tsunami manuals that came with your locomotives. Some locomotives also have a built-in rheostat for manually turning down the master volume. These are sometimes located under the water hatch on the tender.
There isn’t a CV for programming volume on MTH loco’s when using DCC. There is a function key that will lower it but you have to mess with it every time you run.
If you look on the tender there is a little hatch that removes. Inside you’ll find a volume control as well as the smoke switch. Here’s a pic with the hatch removed.
I just purchased the same engine, I am bit confused about changing the address. I understand all the steps, however changing cv17 set to 209, and cv18 set to 169 allows a long address? Then CV29 allows you to type in the long address? Is this correct?
I’m thinking about getting one of these models but the trouble is my turn radius is 18 degrees everywhere. MTH states on its site the engine can operate on 22 degree turns but I’ve seen 18 degrees mentioned in other places. To the guys who own these models, have you tried operating them on 18 degree turns? Does it work?
These models might cost a bit more than the other ones available out there but they are well worth it. I own both an MTH Challenger and an Athearn Challenger and greatly prefer the MTH version, I’ve just about forgotten the Athearn. To me, the MTH version has better sound and the synchronized chuff and smoke is so much better than the constant flow and sometimes sputtering actions of one of the Seuthe smoke generators from other models including my Athearn. Since I already have a lot of locomotives, I’d rather save up my money to get one of these models with all the bells and whistles.
So, after setting CV29 to 34, I simply keyed the first two digits of my desired 4-digit address into CV17, and then the last two digits into CV18. For example, if I want my loco address to be 1234, I keyed 12 into CV17 and 34 into CV18.
Setting CV29 to 38 to use the cab address is a great shortcut, it’s just that a couple MTH turbines that I have had two digit cab numbers, so I tack on two more digits. I use the same two digits for all locos with two or less digits for the cab number so it’s easy for me to remember.
I should also note that the above steps were done with an NCE system, which apparently does the binary value translation for you, thereby allowing you to enter the actual address values into CV17 and 18 without doing the conversion.
When is MTH going to join the twenty-first century and allow the use of a programming track so as not to completely wreck the programming of other loco’s when done on the MAIN!
I don’t have any experience with this engine, so keep that in mind when I say that, if the manufacturer states that it is recommended for 22" radius, and you wish to run it on a radius that is effectively 20% shorter (!!!), you are probably inviting a probability of trouble in the order of 97%. If the prediction is that a typical user is only 5% likely to experience problems running on 22" radii, and if the standard deviation for the probability function is, say, 2", then you are going to be something like two standard deviations into the ‘red’ end of the bell curve of a standard normal distribution. In other words, the ‘red’ is going to be from a nose bleed when your blood pressure rises to catastrophic levels after a week of trying to coax this fine model locomotive around 18" radii.
To help with an example, the BLI PRR J1, a 2-10-4, is recommended for 24" minimum radius. Our hosts here, when they tested one, found that it could get around 22" radius, a much smaller difference into the difficult range. But they didn’t say it was working at track speed. I suspect they almost walked it through curves that tight. You are asking if an MTH 4-6-2 recommended for 22" radius will run on 18". It may, but are you willing to walk it all the time, or accept rerailing it often?
Maybe someone with some actual first-hand knowledge will answer in the affirmative, in which case all I have contributed is a bunch of hot air. I guess it wouldn’t be the first time… [:$]
