MTH BURNT UP
Just had a MTH decoder go out on a HO sd70ACe with sound, what is a good sound decoder that will fit in this locomotive without any changes to the shell.
thanks
My vote would go to a Loksound decoder. You would want file number 73425 as it has the correct air start for the SD70ACE. You can listen to a sound sample here …
http://www.esu.eu/en/downloads/sounds/loksound-select/loksound-select-usa/?tx_esudecoderprojects_pi1[page]=2&cHash=518df4b0dd4c28ff3db12c00a6473b46
Mark.
Thanks will that go in without any mod? to shell
I haven’t actually done that conversion, but the Select decoder is no bigger than any others, and if you are really concerned, the Loksound Micro is one of the smallest available and will still work fine in your engine.
Mark.
Roadie:
The Loksound Select decoder measures 1.18" x .59" x .27". Measure the MTH decoder and see how they compare.
Dave
Fixit I just tour out the MTH and replaced it with a Soundtrax problem solved
thanks
