I am using the MTH catenary system, it won’t be powered because i use both TMCC and DCs. Although i am building a hi-rail layout the catenary seems to fit in even though it is not totally prototyical. It looks right but i was wondering if anybody else is using it and if you have any tips or things that you have done to make it look even better. Although some people think the poles are too tall but i have looked at the catenary along the main line in Phila. and the poles look just about right in height.
Thanks, Dave
Hi Dave,
I’ve got MTH catenary on my basement layout. You are correct that the pole heights are similar to those of the PRR. Those prototype poles carry other utility wires above the catenary. On my layout the MTH poles straight from the box looked too overwhelming, so I cut roughly three inches off the top of each pole and another inch off the arms. I also spray painted them maroon. I felt the silver, once you see the poles in quantity on a layout, was too distracting. I also tried to put the fitter sections in places that were partially hidden by buildings or scenery, since they look very different from the regular sections.
I didn’t power mine either, but the first question anyone asks about the catenary is “does it have power?”
Sincerely,
Neil Besougloff
editor, Classic Toy Trains
Thanks Neil, I read your article in CTT concerning your catenary and they do look good, looks like some rust on the poles will also make them look better. Thanks again
Dave
