I’ve been using DCC since the mid-90’s, but have decided to switch to MTH DCS. I have the system, but would like to learn a couple of things from the experience of others.
On my Digitrax controlled layout I use DCC Specialties PSX for circuit breakers, and OG-AR for reverse loop control. I want to have the same capability with DCS, and would like to find out what others are using.
I tried inserting the PSX between the TIU and the track but got no response from the loco (the two LED’s on the PSX did light, so there was power to the breaker.
I found a short article saying that the Bachmann DCC Reverse loop controller will work with DCS, so that is an option for the reverse loop.
Is anyone on this forum using DCS HO? If so, what have you found as a solution for a circuit breaker and reverse loop controller?
Thank you in advance for your help.
