MTH F3 stuck in neutral
I just purchased a used set of MTH Atlantic Coast Line F3AA. No instructions came with it. I placed them on the track (Z-1000 transformer) and when I move the throttle, I get two rings of the bell and the motor sounds come on. However I cannot get the locomotives to run. Moving the throttle back to off and on again does not put it in forward or reverse. Will a full reset fix this? How do I do a reset? Also how does one identify which version of Proto Sounds does the unit have?
Thanks,
John Black
Wrong forum. I think this is a AC O gauge. Look through the forums. You will find the proper forum. Not many look in this forum. Some new people post right in the first forum they see. Good luck.
I believe it is the Classic Toy Trains forum. Go look.
