I just purchased my first MTH engine and decoder which was factory installed.
Bmy first MTH I have a few questions I need help with:
the maximum speed is way to fast, can I simply change CV 5 to lower it? If so I don’t see the acceptable values. Typically they are between 0-255 but I want to make sure before I monkey with it.
Momentum. What CV do you use and what are the acceptable values?
Can you change the Horn,Bell or lighting sequence? I don’t see options in the instructions.
Thanks in advance for your help
Gary
