I need to remove to roofs of my mth passenger cars to install passengers. Can someone tell me how to get them apart?
go the the MTH site. you should be able to get a parts break down that will show you how to take the cars apart. I did this with my M1a.
thanks for the information. I will give that a try
I went to the MTH site but service page has been removed. So if anyone knows how to remove the roofs to my Madison cars I would really appreciate it.
If these are Rail King cars there are two screws underneath them one on each end. The trucks may be covering them but you should still be able to get to them. Remove the two screws and firmly pull the top off slowly and you may even need to pop a corner of with a small screw driver. If these are Premier cars unfortunately I cannot help you.
Kev
once you remove the two screws, you may have to twist the sides of the car and the top will pop off.
thanks so much for the information. I did not see these screws.
