This is a known problem with MTH Proto Sound 3 locomotives. Out of 3 locos a friend bought, 2 of them have the same problem. The only thing to do is to return those units to MTH for servicing and hope to receive them back repaired in some distant future.
Unfortunately there is not much one can do to modify any factory settings in these locos.
I personally bought 2 SD70 ACe DCC ready. Both units run so hot that they will melt/ fry decoders. Again a known problem and the fix is to replace the motor.
MTH don’t reply to their customers, after sale service is non existent. My units where bought last January and after a first email from MTH requesting for Amps reading, they are ignoring me since. My last email to them was March 2011 and I am still awaiting for a reply. I am thinking they are stretching time until their warranty, if any, expires.
I finally located one of their service center some 100 miles from my home and ordered at my expenses 2 motors. It took MTH a month just to reply to their service center to give the price of these motors. How long will it take to receive them, only God can tell.
Craig Hepburn:Same problem with my MTH SD locos they all have bad motors,Can you let me know where to get motors for them dont wont to deal with MTH anymore.
MTH is frustrating
Changed address to 19 and it works ok until track power is turned odd then it goes back to 03
same with long address
Craig Hepburn:
MTH is frustrating
Cannot turn the sound down f6 and f7 do not do anything - the pot under the radiators does nothing and it is so loud its infuriating
Is there a CV that controls sound volume?
Craig Hepburn:
MTH is frustrating
MTH web site offers no solutions and they don’t reply
Any solutions our there
MTH don’t reply to their customers, after sale service is non existent. My units where bought last January and after a first email from MTH requesting for Amps reading, they are ignoring me since. My last email to them&n
I live in United Kingdom. I own several MTH SD70aces with Proto Sound and overall I don’t have any problem with programming the address on my Lenz 100 with the exception of two of my SD70aces.
Two of my locos had the same problem with not retaining the address. This was approx 10 months ago. I reset using CV55 but to no avail. I even followed the instruction to leave the loco for 20sec before turning the power off but the problem still remained. I eventually e-mailed MTH. Luckily I had a reply from customer service dept after several days. I decided to remove the sound boards from each locos and send them back to MTH. Sending the two locos back to MTH from UK would have been very expensive. After a month, the boards were sent back with instruction to replace the large capacitor at the rear of the loco. I don’t think they serviced the boards, otherwise they wound have replaced the capacitor themselve!!!. Fortunately, It was a straight forward procedure and hey presto it works…the board kept the new address.
I then decided to simply re-connect the other sound board to my second loco(as an experiment). This time even without changing the capacitor, the board kept the new address. So…I wonder whether by simply disconnecting the sound board from the loco say for a few minutes to allow the capacitor to discharge its ‘memory’. Its worth trying before sending the loco back to MTH.
I tend to take photos of the steps taken whenever I opened any loco to do some tinkering. Unfortunately I don’t know how to post the photos to this forum. There are two large capacitors at the rear of the loco (2.5V 1F).
When removing the shell there are 4 tabs located above the trucks. You have to press them outward with a thin screwdriver. You also have to disconnect the railings from the Cab before pulling the shell off.
I haven’t tested the couplers on my loco despite having own 6 DCC sound version!!. I also have 5 DCC ready version!!
There is a youtube video made by The Monster to make slight modification to the automatic coupler. Just type MTH coupler. Its worth watching.
Removing the shell is slightly tricky. First you need to disconnect the hand rails from the front and side cab(using tweezers) as per MTH instruction(I use the DCC ready instruction manual). I leave the rest of the hand rails in situ. MTH handrails are pretty tough though you may chip the paint slightly. Then turn the loco upside down. Instead of removing the truck bottom plates, I simply used a very thin baldder screw driver to disengage to release the tab from chassis. Do this carefully as you might may end up breaking it(how did I know that??). You need good lighting and eyesight for this process. If you struggle then remove the truck bottom plate but remember the position of the wheels!!. Be careful not to bend the freed ends of hand rails(flip them outward) before removing the shell completely off the chassis…I had to remove the whole shell in order to disconnect the sound board. If you remove only the roof hatch, you can’t have a good view of the capacitors and the sound board.
Good luck and I hope my theory works. BTW, I had to pay the UK custom charge plus parcel force delivery when I received the soundboards from MTH as they did not declare them as gift on USPS form. Can you imagine if I did send the whole two locos, it would have cost me a fortune!!
The fix for MTH locos is replacing the 2 super caps on the back. I used 2.7v 1.0f from Amazon. pac of 10 $9.99. I also use these building my own Keep-A-Lives
