MTH Passenger car lights
Does anybody make a LED light that will replace lights in MTh passenger cars without rewiring.A buld that is just exchanged with the incadescent bulb.
[#welcome]
Check the attached link, they aren’t really cheap if you have a lot of cars to change-out but they do look good. Also forgot to add, they are not just a bulb replacement but not that bad.
http://www.scottsodds-n-ends.com/universal_led.htm
Thanks Doug.Was hoping for a simple swap thing.
jim
I think that there are some out there but the biggest problem with the “simple swap” type is not exceeding the max voltage restrictions. If memory serves me correctly once you get above 14v the life expectancy of the bulb goes out the window. Unfortunately my passenger cars are operated in a TMCC or DCS environment which would probably blow the bulbs in just a matter of minutes.
Doug.
I run DCS.Maybe I will try the lites from scotts odds-en-ends.
Thanks again,Jim
