MTH PRR SIGNALS
I have several questions…How many signals has anyone hooked up to the Scale-Trax infared sensor? I have a four track mainline, would these sensors function across two tracks reliably? I am looking to scratch build 4-track signal bridges using the MTH add on signal heads that they make for the PRR signal bridge. Does anyone know the pin configuration? I have 5VDC regulated power supplies that I could use dropping resistors to get to 3VDC. If anyone has experimented with this scenario your knowledge would be helpful.
I wish I could help, but it should be feasible. I havent got the detector for my MTH PRR signal bridge yet, but just having it hook up to give a clear on my main track and the rest showing stop looks good! Keep us all posted on your progress. Cheers Mike
All I can tell you is that my MTH position light signal has ceased working, and now goes from “STOP” to “CAUTION” to “CAUTION/STOP” combined, but no “GO”.
This is using the MTH weight activated track contactor.
Jon [8D]
Kooljock, try connecting power directly to the black wire and the green wire and see if it will go from caution to a clear signal, the contacts in the track thing might be arcing causing it to hold a caution signal, I know my signal bridge is tempermental, I plan to wire up a relay network using an insulated rail to fire the signals. Cheers MIke
