Until I get another transformer, im pretty much stuck with the CW-80 that came with the Polar Express set. When I place my Dash-8 Santa Fe on the track and plug in the transformer, the bell sounds and the loco starts up…but the problem is, I cannot change the directional state of the engine unless I disconnect and reconnect one of the terminal wires on the track, and then I can change states, but I would have to dis/recon the wire each time I want to change direction. It also will not respond to the Direction button on the transformer either.
I believe that the power has to be totally interrupted from the track in order to change directions.
Now with the CSX SD-60 engine (also a PS1 model), when I place it on the track I hear nothing after I plug in the transformer, I can start it up normally once I up the throttle, and can change directions just fine w/o having to disconnect/reconnect any wires. And it responds fine with the Direction button.
My Dash-8 seems to be quite finicky…dont think it likes the CW-80 very much. Eventually though I will get another transformer with the pure sine wave and that should solve it.
Chris
