I am having a problem with an 042 MTH switch, the switch will snap back and forth just fine but as soon as the train goes to the inside loop the switch will not switch back and goes dead. I am running AC power to it but it still gives me this problem. This setup worked great on my carpet layout but as soon as I moved it to the bench layout I can’t get it going right. Any help would be great.
Shim the controller or move it to the other side of the switch. I have seen bad connectors on the switches before, the carpet allows enough flex for it to work were as the hard surface does not.
I have tried changing the controller to the other side and that didn’t work. I disassembled the switch nothing burnt or shorted out. The center rail is not touching anything it shouldn’t. If I disconnect the switch from the inner track the switch will throw just fine even if the train is on the track inside the main loop. As soon as I reconnnect the track back together the switch will no longer throw. The switch seems like it wants to throw but shuts down after struggling to be thrown. It definitey has enough power. I also tried putting jumperson the rails to make sure they all had power. I have no problem buying a new switch but I am possitive it’s not the switches problem. $ 70.00 for a new switch only to find out it’s not the Switch. Here in LA the shops don’t take returns or I would buy another one just to try. Hopefully this explains it a little better but I am at the end of my rope.
