MTH Z-1000
Bought a ‘new’ in the factory sealed box a Z-1000 on E-Bay., When it arrived was not in a factory sealed box and appeared used. But the question is, there is a track connector pictured in the instructions. Is this supplied in the Z-1000 package along with the cables, or is this an extra item???
Hello, I have only ever seen the ‘Lockon’ supplied with the Z1000 when you buy a complete MTH Train set. Even on the MTH website, from what is said, not even the wires come with the Z1000, only the Z and the Brick. As far as the condition, you might want to contact the seller and state that the received goods were not in the described condition. I suppose that it may have just been tested, but even with that, it should not have said it was sealed. Perhaps a suggested return of some funds may be agreed upon, that is if it runs fine.
Tim
Just for your Inf I bought three (3) MTH Z1000 transformers from ebay sellers and each one had a track connector, red and black wires with them. Plus each one was in a box.
I have bought two MTH Z-1000’s brand new and both had the wires with them, red & black wires with banana plugs on the ends. The instruction manual came with each Z-1000 but no track connector came with either Z-1000.
The only time I didn’t get any accessories with a Z-750, was when I bought it used at a train show for $15.00, got just the 75 watt power brick. I am using that to power my TIU base.
Lee F.
