Multi-level layout lighting
I’m in the process of building a two level layout using Bill Darnaby’s hot-wire foam board and L-bracket construction but I’m having trouble deciding on how to light the lower level. Questions:
  1. How do you mount incandescent bulb recepticles onto an 1/8" masonite fascia?
    2)How do you mount the wire to the same masonite? (I’m running 2 lines - one for white and one for blue lights)
  2. My upperlevel base is 2" foam. How do I keep the lower level lighting from melting the bottom of it? (I’m using 60W bulbs)
Thanks for any help you can give.
Tim
Another option is to try rope lighting. I am using this method to light the bottom of two levels, with 20 inches of seperation. I painted the bottom of the top level white so that more light would be reflected downwards. For the amount I am using it will total the output of about one 100 watt light bulb. I have come to the conclusion I might have to run a fan for air circulation (heat) during op sessions, though by myself it isn’t too bad.
You can get “rope Lighting” at stores like Home Depot.
I’d use flouresent. Very little (if any) heat, mutiple colors and easy to install+maintain.
Something that i have planned to do for the last year or so is to use "Christmas tree " lights from Provo Craft or Sylvestri clipped under the fascia. These are already UL listed and made so that they will NOT ignite even dry christmas trees. I had planned to have white, yellow, redorange, and blue with programmed fading (x10 light controls) from yellow-white days to yellow red sunset, to blue nights. also white-blue if i wanted to simulate rainy days or over cities program blue with faded yellow red for city glow.
soulds like a bunch but is not and I prefer the opinions of UL to mine where safety is concerned.
Doug, in Utah
