Hello All,
I run Bachmann diesels and a couple of steamers; USRA 0-6-0 with a Vanderbuilt tender and a 0-4-0 Dockside Porter.
All have Original Equipment Manufacturer (OEM) Bachmann decoders, all non-sound.
The problem with Bachmann is their OEM DCC decoders- -both the drop-in PCB types or the NMRA 8-pin compatible.
Bachmann non-sound decoders do not support the Configuration Varriables (CVs) that are necessary to successfully speed match- -CVs 5 and 6 (V Mid [6] & V Max [5]) or CV 21 & 22 for consisted function controls.
My DCC pike has a dedicated programming track through the cab. I also use JMRI Decode Pro linked to my Mac with a Digitrax PR3 to a separate programming track.
I have two sets of Multi-Unit diesel consists with Bachmann decoders. One set is four GP40s and the other set is three GP30s.
Yes, these will consist with basic or universal consisting but they don’t support advanced consisting or, as mentioned, speed matching.
If you are freelancing your pike you can augment your steam motive power with diesel on steeper grades, but speed matching might not be possible and cause more problems than it’s worth with the Bachmann OEM non-sound decoders.
Prototypical railroads, in the steam era, did double- and triple-head steam locos before the advent of diesel power.
Have you tried this on your grades with the motive power you currently have in inventory?
I admit that I don’t know much about steam locomotives. I suspect, depending on the type, they might be better MUed with each other than with diesels, if the decoders do not support speed matching and/or advanced consisting CVs.
The “best case practice” would be to replace the OEM Bachmann decoders with others that support the needed CVs for speed matching and consisting. (I have a cow an
