My Final Plan...Finally
Well, the layout is still at a stand still, but I finally have the absolute final plan (subject to change pending critiques.) Anyways, here we go:
http://s57.photobucket.com/albums/g239/DerrickKM/Track%20Plan/?action=view&current=derrickslayoutxtc.jpg
The layout is based on Lance Mindheim’s Miami layout. The emphasis is one or two trains servicing a small shortline, and a small power plant with their own switcher. Trains delivering coal from the powerplant arrive from the bottom right, while trains switching the industrial yards originate on the top left staging yards.
Any comments, please let me know. I am open to any critiques. Thanks for your time!
Looks nice!
I’d add a runaround somewhere, tho!(that’s just me)
Good luck,
Terry
Thanks for the suggestion Terry. If anyone has any suggestions as to where to fit in a runaround, that’d be great.
Yep!! You do need a runaround somewhere.
I would locate it on the bottom L part of the plan. I would move the siding at the bottom to the right some, then put it between that siding and the main, with the turnouts for the runaround just outside both of the two turnouts for the sidings at the upper part. Kind of hard to explain it without drawing it.
You might also want an escape at the end of one of the powerplant track. So you can take the empties back from whence the loads cames, rather than continuing on.
After forty years in the hobby the one piece of advice I would give you is no plan is ever final.
I myself am going through the design thing right now along with some great input from other posters and have revised my plan accordingly. Everything is subject to change.
As for myself I would add a turning wye in the corner. (to turn the Locomotive)
Along with a run-around. (to run the Locomotive around to the other end of the train)
Or just an engine escape at the end of the power plant leads.
Wanna bet a steak dinner?
There is an old military axiom which says that no battle plan ever survives first contact with the enemy.
My suggestion: build the benchwork and lay out your track. I like doing this as it inspires you to keep working. don’t fasten the track down. try out your current arrangement. it is possible to do without a runaround. then, try a runaround see what operates better. this usually helps determine my “final” plan!
Hope this helps!
