I was working on my HO Atlas C30-7 last night, adding two small pieces on the Air Tanks (Details West Part 263, for 4 & 6 Axle GE Locos).
These are tiny parts that attach on the edge of the air tank- not even sure what the actual part is! [:)]
(In the image at http://www.walthers.com/exec/productinfo/235-263, this is in the middle diagonal row, second from the left.)
From the instructions diagram, and from what I can make out in the shadows of prototype photos, it appears to be attached similar to what I’m attempting to show in the following image:
The instructions suggest drilling a hole (#77, IIRC), and there is a nice long sprue which, in theory, would fit into said hole and provide a nice mechanical fit. However, I was unable to get such a small hole drilled at that large angle on the curved surface of the air tank- finally gave up, having dug a small divot and afraid that I would do damage that would be hard to fill in.
What I ended up doing was CAREFULLY setting the loco at an angle, then trying to set the part in place, and apply a drop of CA. When all went right, surface tension pulled the CA into the gaps, and it looks like it’s cemented on nicely now. I was able to get it right, but I kept disturbing the part, so it took about three-four tries.
What was frustrating was that I couldn’t figure out how to keep the silly piece in place- my “third-hands” both have alligator clips that, if I could get a sufficient grip to hold the small piece, I was afraid they would end up part of the model! Trying to hold the piece with the tweezers, I couldn’t hold it still long-enough for the CA to set, much less long-enough to set down the CA bottle, pick up the accelerator, and apply.
So… in such circumstances:
- difficult to get good mechanical joint
- too small to get a good grip
- not enough hands to apply CA accelerator before the
