My latest distraction, after reworking the portable I had a bunch of bluefoam, wood and a 21" circle just laying around, I hate that, so I thought I’d try throwing them together …
Still mucking about with it, maybe one day I’ll actually be able to take it to a show somewhere
Fantastic, but you sure do have a future in politics. I don’t believe you have demonstrated individual control, running one slow and one fast (an impossible feat as are most political solutions), so you demonstrate something else. Bravo!
Blue foam, pink foam, Geodesic foam? What’s the difference? Pink foam is extruded foam, right? Geodesic foam is totally different, right? So what is best?
Pink foam and Blue foam are both the same foam, extruded polystyrene, but from different manufacturers. I use the blue Dow foam because I have a local source for it. The foam has a dense texture, cuts and carves really well. I bought a Woodland Scenics foam cutter and it does make working with the stuff MUCH easier to shape and form.
Geodesic foam is a 2 part mixed foam that has to be poured over a latex form to get the rock texture, that is then layed over either, I just learned to carve the rock forms into the blue foam but the geodesic stuff looks way better when painted correctly
DO NOT USE WHITE STYROFOAM, the large beaded stuff used for shipping packaging. It is a hellish mess to shape.
Thanks for the information. I did a little research on foam cutters and if I was going to buy one I’d go with the Hot Wire Foam Factory products. Their products are a bit more $ but I think they’re worth the extra few bucks. The “Pro” tools are pretty cool-take a look at them.
