So Im a bit embarrassed by my voice over but I couldn’t leave the video as is.
If you’re not sure about what your watching- I took my tiny Nscale layout and tried to film it in the most realistic style possible with a story attached. Tell me what you thinK!
Thanks for the comments guys! I would have done let it snow if it had been before christmas, but I was too late! I know for a fact I would have been able to pull this off better with lionel or HO just because of the camera depth (In order to get that close with so much detail you need an expensive lens) and they run much smoother at slower speeds.
As for the voiceover work, well…I’ve never heard that before but thanks!
I think your voiceover sounds just fine, and the tone just right. From a technical standpoint, you should put a pop filter over your microphone (or at least the microphone foam) to keep the “P” consonants from overloading your signal.
It should also end with the word, “FIN”
The only part I didn’t like was the Atlas bumper track, but that’s just me
And as for N-scale not running as smooth as HO, you should try a Kato locomotive sometime!
